Hello everyone.
I had a question about wheel and tire fitment when moving to 20" rims. After much searching, I finally found a lightweight wheel that I don't think looks like crap.. lovelove
The winning wheel is the AC Schnitzer Type V Forged - Black with Machined Face Finish. I wanted to do 20 x 9s in the front and 20 x 10s in the rear, but I'm a bit confused on the offset. I notice many of you have had to use H&R spacers after changing to custom wheels to get the fitment that you like.. I'd like to choose the proper offset so to avoid any wheel spacers (if possible).
Here are the wheels I'm looking at:
Front Rims -- 20 x 9
Rear Rims -- 20 x 10
As you see, the 20 x 9 offset choices are 15 and 22 and the 20 x 10 offset choices are 13 and 33. I assume I want the +22 offset for the fronts and +33 for the rears, but I'm not sure.
Also, I'd like to run 275/30ZR20 in the front and 305/25ZR20 in the back. Will this work and retain nearly the same wheel height as stock (so I don't have a whacked-out speedo and other problems)?
Thanks for the help -- I know many of you are running 20" rims and have already faced these questions in the past (though concerning the offsets, I couldn't find any old threads that matched).
-b.
-b.
