1 - 3 of 3 Posts
Hey guys so im looking to get the 2010 competition M6 wheels for my E60 M5.
The size in the rear is 19x10 (half inch wider then normal rim) and a ET: 22 (standard M5 ET:28)
BMW runs 285 tires on these comp wheels and i will be doing the same..
Anyone have an idea if these will rub? Doing my math, looks like these wheels will have the same inner clearance but will stock out 12mm more then the stock M5 rims, so basically like putting a 12mm spacer on.
I have seen alot of mix mentions of 12mm spacers rubbing and not rubbing on this forum.
DinanS2+ e60m5 6MT, s38b38 e28m5 TT/ST3, e30 TT/ST4
I'm running a fat 305 PSS on 10" wide wheel, no spacer in the rear...my offset is 25. I only get slight rubbing on deep compressions.
Details are in my signature.
Reactions: lumi
Yea i like your setup! I think your drop, and the extra 305 rubber is putting the setup i want in the clear..
I would run a max 295, and on stock suspension...
The rims i want are the 2010 M6 comp package wheels which are .5 inch wider in front and rear.
1 - 3 of 3 Posts
