1 - 10 of 10 Posts
Now, I have been told putting on 19's on the beast would basically mean replacing my tires every 10000 kms. Is this true? I just bought new 18 inch rims, and love them, but I see alot of cars with larger wheels, and I gotta say, I LIKE IT.
I do drive my car about 20000 kms per year, but I can't afford to go through two sets of tires every year.
Your thoughts?
Your thoughts?
I wouldnt have said that the diameter of the wheel makes a difference to tyre wear - the side walls will be smaller that may cause some kind of additional wear due to higher stresses etc, but i cant see that a 35 would be much differnt to a 40 profile.
if you were going up in width then i may be able to understand it better -
Main issue with going from 18's to 19's is the additional weight. If doing it make sure you do a good light wheel like a BBS or OZ etc
cheers
Your thoughts?
Assuming similar weight and proper offset, I don't see why larger diameter would have a major effect on tire wear. You will certainly be more limited in tire size and choices, but driving in a similar style should yield similar mileage. No empirical data, just a SWAG.
Stop listning to morons.
You could keep the same amount of sidewall as well, simply run a 245-40-19 Or somthing like a 275-35-19 sure thats wider and taller but about the same amount of side wall. Just becuz it's biger does not mean it wears any quicker. Next time you hear from who ever told you that slap um.
I agree, using a 19" wheel vs an 18" wheel should not make any difference in tire wear. Maybe since tires for the 19" size wheel are generally more aggressive, i.e., softer rubber compound, and wear faster than "normal" tires, that's why some people think that it's the wheel size.
Wilkie
I would normally agree with everyone here, but... I just switched from the factory 18s to 19s and am having trouble with tire wear. I had Pilots on my 18s and they lasted about 20k or so. I put SO3s on the 19s and they are struggling to last 10k as of now. I had the alignment done when I got the new wheels and tires... everything was in spec. I am actually a bit frustrated. My driving habits/style has not changed at all as far as I know either. I am sure that some of the difference has to do with the differences in the two tire models, but 10k worth of difference... I don't think so. I am surprised that no one else has experience this... maybe the SO3s just suck at the lasting of the longness.
Eric
· Moderator Emeritus
Eric
S03's uses a much softer compound that pilot sports. Doesn't matter what size S03 you use, they will not last as long as the pilots. I've had pilot sports on my 19's for the past 20,000miles, and the tread is holding up fine. Looks like it will hold for an additional 10k miles. If you do a search on the old threads, it's been discussed that S03's are crap on such a heavy car as the M5. They were designed for much lighter cars, and thus the tire wear most people experienced while using them were similar to your results... 10-15k per set of S03's on the M5
goodyear eagle F1's lasted twice as long as Pirelli 6000's on my old M3. Amazing the difference the brand type can make.
1 - 10 of 10 Posts
