1 - 20 of 53 Posts
i bought this car from a person out in California. its one owner with only carfax documented 87K miles on the car. the person told me it does not run so i got a good deal on the car. I got it shipped to florida and having my mechanic take the whole engine apart and going thru it all. I will have pics up soon. I took other parts to get powder coated same color.
Discussion Starter #2
here is few pics of the car. not bad shape all pixels work and has all keys with key-less remote. has the cd changer in that back and most of the tools are intact in the trunk. has aftermarket wheels but will switch them out. first get car running
Im tyring to upload more pics but files to large.I guess someone tried to service the engine and messed it up.
right now engine is apart getting 12 new intake valve new springs
installing new oil pump just for the hell of it.
new chains and guides might as well
pistons will be inspected and replaced if need be will post up on that.
keeping everything all matching numbers car with 87k miles on it.
Looks fun ;) I had most of that done to mine a couple years ago, but only the head/valves/chain, etc. Bottom was good, so did not pull the engine completely.
So what was "messed up"? Hopefully not broken....
the intake valves are all bent when we took engine apart. Im guessing the previous owner took to get serviced and they tried to do valve adjustment and was a few degree's off and bent all intake valves.
I wish i can give you an answer that is what we saw when we took engine apart. The intake cams are bent. The seller just did not give specific when i bought the car from him. I asked him why does the car not run all he said is "I don't Know". but for the price I took a gamble and its costing me a few bucks already. But I want to do it right and all OEM parts plus while the engine is apart why not install all new parts. I will post more pics of parts being replaced. the bottom end, cams and cylinder walls all solid.
Looks like you might also be looking for an M5 front bumper!
Always fun seeing engine pics! Good luck.
Discussion Starter #11
update
ive been very busy with work but motor moving along just nicely
all new intake valves installed and seated buckets cleaned and adjust
Line-bore done
new piston rings
new rod maine's
the pistons were put in a bath for 4 days to get cleaned.
the head was water tested for any leaks
the block was also clean and and inspected
Im sure im missing a few more steps been at machine shop for a while
new oil pump
new water pump
new thermostat
new timing chains
new guides
ALL OEM BMW PARTS
here are many pictures.
Discussion Starter #14
more pics
more
Discussion Starter #15
more pics
more pics oh i forgot new head bolts
new motor mounts will list more as i get closer to finish.
will also be installing new clutch fly wheel pressure plate and pilot bearing sachs
Discussion Starter #18
detailed photo's of the line-bore
line-bore
1 - 20 of 53 Posts
