1 - 2 of 2 Posts
so I saw these wheels for sale used, 18 x 9 with offset of 20. my question will this fit in the front
I sure the rear is fine, but need to find out soon before they our sold so if anyone has done this let know please
of this is for a e34 m5 with h&r springs/bilstein shocks
thanks mike
Here is my old 3.8L with 18x9.5 et22 wheels. I believe I had to run a 10mm spacer to clear the KW V2 coil overs with camber plates. You might have better strut clearance with the factory struts, but a small spacer might be required. Tires were 255/35/18 square. There are many interactive websites that can help you visualize the difference between your current wheels and your new ones, simply google "wheel offset calculator" and start plugging the data in!
1 - 2 of 2 Posts
