1 - 5 of 5 Posts
So as the title states i opened her up one late night on a diclosed stretch of highway and it just kept pullin and pullin til i let off around 175.... so what gives? ( not that im complaining) but i thought our cars were limited at around 155 being in stock form.
Its possible yours may have been reflashed by a previous owner and you are not aware of it. I drove a local guys M5 and noticed the throttle response was much different than mine, felt smoother and then he ended up doing about 170mph. Later found out he had the dinan software.
The thing is that it WAS chipped when i purchased it... I later had to have it reflashed back to stock for emmissions purposes and also found out i had the dreaded AA code at that time also..
2 different items, but can be done (and usually are done) together.
One is to reflash for better performance, the other is to remove the top speed limiter, which kicks in at about 155 mph. Should go to around 162-164 based on normal speedo error without being delimted. Real top speed should be over 175 mph (real) depending on how hard the engine can pull in top gear.
1 - 5 of 5 Posts
