Performance
Power output: 1 MW at 7500 rpm - rpm limiter @ 8250 rpm
Torque: over 1000 Nm from 3000 to 8000 rpm
Max torque: 1371 Nm at 6000 rpm
0 - 400 km/h approx. 20 sec
400 - 0 km/h approx. 10 sec
Braking distance: 28 m (100-0 km/h)
Max lateral g-force: 2.0 g
Emission levels: Euro VI
Aerodynamics
Cd 0.45-0.50 with adaptable rear wings
Frontal Area: 1.910 m2
Total Downforce at 260km/h: 610kg at 440km/h: 830kg
Flat underside of chassis. Venturi tunnels at front & rear of chassis/body
Active aero front and rear underside
Active triplex suspension
Maximized intercooler flow
Dimensions
Total length: 4500 mm
Total width: 2060 mm
Total height: 1150 mm
Ground clearance: Rear: 74-90 mm Front: 59-100 mm plus 50 mm lift system
Wheelbase: 2662 mm.
Front track: 1700 mm. Rear track: 1650 mm.
Front overhang: 944 mm Rear overhang: 900 mm
Fuel capacity: 74 litres
Curb weight 1360 kg (complete car ready to drive with 50% fuel,
100% fluids)
Weight distribution: 44% front, 56% rear
Transmission
Specially developed 7-speed dual clutch, 1 input shaft transmission with paddle-shift.
Electronic differential.
Chassis
Advanced high modulus carbon fibre chassis with F1 style honeycomb core and integrated fuel tanks for optimal weight distribution and safety.
Monocoque torsional rigidity: 65,000 Nm/degree.
Weight: 72kg.
Double wishbones, active ride height control and bevel carbon fibre springs with variable spring ratio.
Triplex damper in the rear.
Needle bearings and o-ringed wishbone bushings.
Fully machined aerospace grade aluminium uprights with SKF LeMans specification 150mm angle contact ball bearings.
GKN hollow/gun-drilled driveshafts.
Koenigsegg Z-style progressive and lightweight anti-roll bars front and rear.
Engine
Koenigsegg aluminum 5,0L V8, 4 valves per cylinder, double overhead camshafts with flex-fuel capability.
Compression: 9.0:1
Bore: 92 mm Stroke: 95.25 mm
Sequential, multipoint fuel injection.
Variable geometry twin turbo chargers.
1.8 bar boost pressure.
Dry sump lubrication.
Carbon fibre intake manifold with optimized intake tracts.
Tig-welded ceramic coated Inconel exhaust system manifold with merge collector.
Weight: 197 kg
Brakes
Front brakes: Ventilated ceramic discs Ø 397 mm, 40 mm wide. 6 ceramic piston calipers.
Rear brakes: Ventilated ceramic discs Ø 380 mm, 34 mm wide. 4-piston calipers.
Traction Control. F1-style for optimal performance with 5 different handling modes.
Steering
Rack and pinion power assisted steering. 2.7 turns lock-to-lock.
Turning circle: 11 metres. Electro-hydraulic power-assisted.
Wheels
Koenigsegg Aicore™ carbon wheels with centre locking.
Front: 19” x 9.5”
Rear: 20” x 12.5”
Tires
Specially developed Michelin Cup 2 tires.
Front: 265/35 – 19” (Y)
Rear: 345/30 – 20” (Y)
Speed rating: 440 km/h
Body
Two-door, two-seater with fixed roof. Body made from pre-impregnated carbon fibre/ kevlar and lightweight sandwich reinforcements.
Electrical System
Unique Koenigsegg developed electronic control systems including:
body, engine, transmission, traction and stability control and power management. Solid state digital semiconductors - minimalizing need for physical fuses or relays. Can bus operated and fully programmable
functionality.
Equipment
Lightweight glass system, power windows, adjustable pedals and steering column, One:1 stitching, adjustable light weight race seats, carbon ceramic brakes, Sport ABS, ESC, active ride height, power steering, power brakes, 6 point racing seatbelts, intelligent LifePo4 battery, USB connection, climate control, digital warning and info system, G sensor, alarm, tyre monitoring system, proximity key, car cover, rear view camera.
Optional Extras
One piece racing bucket seats, active shock absorber settings, full clear carbon body, custom body striping, upgraded audio system, painted calipers, personalized logo on rear hood, anodized black aluminium interior, custom leather One:1 custom luggage set, custom diamond encrusted key, titanium exhaust outlet, active noise cancellation, 3G telematics system, variable turbo geometry.
3 Year Warranty
