1 - 4 of 4 Posts
2006 E60 M5 SMG
Hi all
New to the forum but any help would be greatly appreciated!
Got a Trans. Malfunction in the dash today right before I about to park the car and done for the day. Everything was fine from the start until I was about to park. It was grinding when it tried to shift into 1st. 2nd and onward are fine (in Automatic mode). There was a every time kick when I shift into reverse and push the gas after the message popped up. I switched the car off completely. 30ish mins later, when I tried to start the car, it wouldn't crank at all. Just ignition on and won't crank. I did use a OBD scanner to try to read any codes, but there was none.
Again, any help would be greatly appreciated!
Best regards
936738
Sounds like PLCD sensor/slave cylinder issue. You need Carly or BMW diagnostics software to be able to read the SMG codes.
+1, ISTA is extremely useful and can be downloaded for free once you have a K+DCAN cable. Worthy investment imo, good ones can be had for $50. On a side note, nice mileage! 156k is nothing to sneeze at.
1 - 4 of 4 Posts
