• Latest threads
    • Custom feed
      • Updates
        Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > GTboard.com: Discuss other sportscars > GTBoard.com: General Sportscars > X5 and X6 Forum
        X5 and X6 Forum Forum for xDrive35i, xDrive50i and xDrive30d. Also for X5 4,8i, 3,0si, 3,0d and 3,0sd.
        Old 5th December 2003, 16:57   #1 (permalink)
        AJ
        What the... problem starting the 4.6is
        every now and then once i turn the ignition key i hear
        "click" and it sounds almost like the engine is turned just a bit and then all dies- the whole ordeal takes about a split of a second... if you try again it will crank and start.
        anybody heard of this?
        thanx in advance
        alex
        02 4.6is
        02 gts
        few other cars
        AJ is offline
        Old 5th December 2003, 17:01   #2 (permalink)
        TCM
        TCM's Avatar
        AJ:
        That is odd. Maybe your battery is low? The 4.6is has a lot of electronic gadgets on it that require a large amount of volts to start. If you battery is not putting out around 16volts at cranking, it may not start the car. Please let us know what you find out.
        Moderators, could we move this thread to the X5 section? May be usefull to other X5 owners.
        T.C.
        '01 Silverstone M5
        SuperSprint:X-pipe
        TCM is offline
        Old 5th December 2003, 17:06   #3 (permalink)
        AJ
        tcm,
        i have plenty of electricity. nothing dims. the battery is in good shape. note that when i turn the key for the second time it turns over and starts the engine just fine...
        i am stumped. i will go to the dealer for this, but i wanted your opinions first
        alex
        AJ is offline
        Old 5th December 2003, 17:57   #4 (permalink)
        M-BarryMore5
        Banned
        M-BarryMore5's Avatar
        I would of thought it was the car batteru but it appears not. I could possibly be the battery within the key?
        M-BarryMore5 is offline
        Old 15th December 2003, 05:15   #5 (permalink)
        Alex5
        Alex5's Avatar
        Happens to me just about every 100 starts. Just a click and nothing, but the lights do not dim or anything, Next key turn and it starts. Beats me!
        Alex5 is offline
        Old 4th November 2004, 05:28   #6 (permalink)
        PCUT
        Re: What the... problem starting the 4.6is
        I have an 02 with 18000 miles that does the same thing. I'm about ready to take it in . I'll let you know what they say.
        PCUT
        PCUT is offline
        Old 9th November 2004, 23:41   #7 (permalink)
        AJ
        on mine they said - "could not repro"...
        dont blame them.. but then again if a few of us have that problem, they should be aware of it...
        alex
        few cars
        AJ is offline
        Old 9th November 2004, 23:48   #8 (permalink)
        PCUT
        Just got back from the dealer who said they had to adjust the key and how it was fitting-whatever that means.
        PCUT
        PCUT is offline
        Old 9th November 2004, 23:55   #9 (permalink)
        Ashok Arora
        Ashok Arora's Avatar
        I think it could be your immobiliser relay. Ask your dealer to check if this is faulty. If you have an aftermarket immobiliser fitted (e.g. keyguard unit) this may be at fault.
        Ashok
        2002 E39 Carbonblack/Caramel M5 (past)
        2005 E60 Blue Onyx/Caramel/Light Figured Ash M5 (past)
        2007 E90 Montego Blue/Black Alpina D3 (present)
        Beware the Red Cog of Death!
        Ashok Arora is online now
        Old 28th January 2007, 06:25   #10 (permalink)
        unfoundhorsepower
        unfoundhorsepower's Avatar
        It sounds like a denuralizer problem, the Manufacturer is having problems with the ones made in Zarta....
        unfoundhorsepower is offline
        Old 30th January 2007, 01:17   #11 (permalink)
        Alex5
        Alex5's Avatar
        What is denuralizer???
        00 M5 Dinan 1.5?+Powerchip
        01 M3 Conv Powerchip gone
        02 X5 4.6is Dinan+Powerchip gone
        04 325x wagon
        86 Porshe 944 Turbo stock
        01 Lexus IS300 Turbo
        Alex5 is offline
