Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > X5 and X6 Forum
X5 and X6 Forum Forum for X5 M, X6 M, xDrive35i, xDrive50i and xDrive30d. Also for X5 4,8i, 3,0si, 3,0d and 3,0sd.
Old 6th November 2009, 00:16   #1
///M5 V10
///M5 V10's Avatar
Garage: e60m5 sliverstone
____bmw x6 exhaust____
hi guys
i want to buy aftermarket exhaust for my x6,but i dono which exhaust must i buy. i search in youtube and web but not found
anything good with again HP & LOUD sound
if any one has experience just till me ,,
///M5 V10 is offline
Old 9th November 2009, 22:33   #2
rkhudave
rkhudave's Avatar
Garage: E39 M5 WBM
Sales Feedback: (-1)
Are you looking for mufflers only? Eisenmann makes it for X5 and X6 the sound is very similar to v8 M5, just a little different pitch due to the fact that one os automatic an the other manual. Unfortunately, people who buy X5 and X6 don't buy aftermarket exhaust that often. if you are looking to change the sound just a little, but not the the extreme of eisenmann. look into AC Schnitzer or Hamann. They look cool and are a little beter than stock.. Either of the exhaust you go with expect to pay anywhere from $1500 to $2300. Of course they are other options like Magnaflow or Borla.
/// 2002 Blue Water Metallic
Performance: | DINAN Strut Bar | DINAN Cold Air Intake | DINAN MAF | DINAN 3.45 Limited Slip Differential | DINAN Stage 3 Software| B&M Short Shifter | Kelleners Race Exhaust 83MM| Custom X-Pipe |
Interior/Exterior: | ACS Splitters | ACS Fog Light Inserts | ACS Diffuser | ACS Pedals | ACS Hand Brake Lever | UUC Shifter Knob RK6A-L height-Adjustable Shift Knob with Leather Covering | ACS Mid Spoiler | 6000K Xenon Headlights/Fog Lights | MKIV Nav |
Suspension/Brakes: | ACS Shock/Spring | Hamman PG3 3-Peice Front 245/30/20 Rear 285/25/20 | Wrapped with Vredestein | Brembo: Front GT Brake Kit 380x32 2-piece 8 piston - Monoblock | Brembo: Rear GT Brake Kit 345x28 2-Piece 4 Piston - Lotus| UUC Trans Mounts |
More coming soon.........
www.Need4SpeedMotors.com
rkhudave is offline
Old 9th November 2009, 23:28   #3
///M5 V10
///M5 V10's Avatar
If I put x pipes without resonetor. It will increse sound slaitly.
And do u maen the Eisenmann its more louder.
Wat about HP.
Old 9th November 2009, 23:48   #4
rkhudave
rkhudave's Avatar
Garage: E39 M5 WBM
Eisenmann is a lot louder... removing resonators and X Pipe will increase the exhaust flow through the pipes, but does not mean i will sound better or you will gain HP. There is such thing as back flow pressure that must exist.
HP gain varies from application to application. With exhaust modification, you will need to re-map you computer. You don't have to, but if you are looking for those HP gains, re-mapping or customs software is the way to go. My car is tuned for all of the add-ons that i have on my car. For instance air fuel mixture must be properly set for the best performance out of your add-ons.
I have Kelleners Race on my E39 m5 and it sounds great, i am planning to purchase 2006 X5 4.8, but will not put the same exhaust the an X5. I will look at less noisier exhaust like ACS or Hamann (just and FYI most of the exhausts are produced by supersprint including Hamann and ACS.
rkhudave is offline
Old 10th November 2009, 17:02   #5
///M5 V10
///M5 V10's Avatar
thnxxxxxxxxx alotfor help man
wait more idea
Page generated in 0.08825 seconds with 10 queries
