Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > X5 and X6 Forum
X5 and X6 Forum Forum for X5 M, X6 M, xDrive35i, xDrive50i and xDrive30d. Also for X5 4,8i, 3,0si, 3,0d and 3,0sd.
Old 8th April 2008, 06:35   #1
Mike Klein
Garage: '00 M5 Dinan
Check Engine Code .....help please
My wifes '01 X5 (E53) 3.0 6cyl, auto ( 1 owner, good services, 113k miles) is throwing a CEL code #0128 ( Low temp sensor reading) and #0141 ( O2 Sensor Fault, second sensor) both codes at once, even after reset.
I noticed on a long freeway cruise at about 65 degree air temp. that the temp gage was reading just below the 1st mark (less than 1/3 up) whereas at idel or around town, it tends to sit right in the middle, straight up. The pusher fan cycles on/off as normal. This would imply that the thermostat is stuck open. But I replaced that T'stat for general goodness about a year ago.
So here are the questions:
1) since I don't drive it much, I don't know what temp reading I should see on the gage. Help?? Can't tell if it's a faulty sensor or a bad T'stat.
2) could the O2 sensor code be related to the low temp?
3) any cheap mail order sources for parts??
Any other help would be appreciated. THANKS.
Mike Klein is offline
Inspection ll SoCalJD E39 M5 and E52 Z8 Discussion 51 29th March 2009 11:36
Key Fob Issue - you too? MAH E39 M5 and E52 Z8 Discussion 15 11th February 2005 21:35
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
pre-purchase inspection paolo E34 M5 Discussion 8 28th April 2002 23:46
SL 55 vs Z8 at the Nurburgring! mmunson E39 M5 and E52 Z8 Discussion 64 21st April 2002 02:42
Page generated in 0.07745 seconds with 11 queries
