Originally Posted by THRILOS5
yes we are...
isn't that the scenario for most street motors though??
except the "legendary" 5.0L
Well....only if they have racey redlines that are frequently explored. This is generally not the case.
The E39 S62 has one of the highest rev limit settings found in a large street V8. BMW engineers pushed the envelope, IMO, a bit too far to expect lifecycle to exceed 100K mi in the hands of all drivers. The S62 cam profile and engine breathing encourages extended use at peak RPM, so the bearings can get a workout and wear more quickly in the hands of certain owners. This racey calibration all fine and great when bearings are fresh and clearances are tight. However, this "extended headroom" racey tuning strategy specifically may lead to extra wear and stress on the rod bearings. Accelerated bearing wear leads to marginal oiling which tends to destroy motors. The S62 is super reliable at peak RPM until the bearing clearances become excessive from driving it in a racey fashion for extended periods.
If your S62 gets diligent maintenance and seldom sees RPM over 6K, then it will likely have low wear on it's bearings.
This is why 4.4L BMW V8's and pushrod GM Vette's and Ford 5.0L HO's are
not seeing such recip assy troubles as they exceed 100K miles. These motors generally do not see elevated RPM over 6K, therefore they see
much less bearing wear. Since their redlines are lower due to lower RPM tuning, they offer a greater margin for safety in senior years. You can take one of these cars to the track with much less risk of failing the recip assy.
If you WANT the same level of safety, risk and reliability from an S62, you would realistically need to proactively change the bearings or set the rev limiter around 6K for the life of the vehicle. This would prevent accelerated wear and it would also provide more margin of safety during flogging.
You take your pick...proactive bearing replacement, don't test high rev's often or accept additional risk.
A thoughtful balance between restraint (limited abuse) and accepting some risk (occasional beat run or track day) will work for most folks.
This issue boils down to safety margin and risk. Mass production pedestrian cars generally have very conservative calibrations. They are designed so a moron can beat on it for 10 years without bad results. Such cars seldom have market-leading performance stats. Unfortunately, racey calibrations & tuning that S62 needed to produce market-leading performance invariably comes wiith a few drawbacks. The rod bearing lifecycle issue resulting from elevated RPM is a notable example. Another E39 example might be the marginal durability of the world-class E39 lightweight aluminum rear axle carrier assembly which can not tolerate uncontrolled wheelhop caused by juvenile owners who wish to lay rubber from a stoplight like a ponycar.
