Nice! I did the same thing this spring. Had the 18" versions and decided to switch to the 19's for aesthetics, and to get a bit more rubber out back. And then I went and stuffed a 380mm Dinan brake kit under them.
Paul,
I run 275/30f 285/30r on 19x9.5" & 19x10".
Your sidewall specs look too tall compared to stock e39 M5 tires - unless you're intentionally trying to run taller tires.
I ended up with 255/35/19 and 285/30/19 I should have went with 295/30 or 275/35 I think i should exchange it.
125.8K members
