Gents
Last weekend I installed a full GC coil-over system on my 2003 E39 M5. I have one of the first setups that include the new-style Ground Control front strut units. They're shorter than the regular Koni yellows by about 7/8" allowing more travel. They're also an attractive red color as well. They ride beautifully. Spring sets are 430F/380R. Rear shocks set at 1 turn, fronts unknown. I'm running 14.0" front and 13.75" rear ride heights, and I'm planning to raise them about 1/4 inch next time I have the wheels off.
My first track day of the season was to be next weekend but it was cancelled. I haven't had a chance to drive the car with the new gear other than to work and back - we've had more record rainfall days with nasty mudslides again. The next DE I'm booked for is June.
The front damper units have a new and interesting characteristic: because they are shorter than the Koni Yellows, the 60mm diameter threaded height adjustment tube comes down far enough that it's in the zone where the tire comes closest to the damper body. My measurements indicate that it uses up about 3mm of the space that would be there with the stock 54mm diameter dampers. In other words, 275's on 9.5's with 3mm spacers may not work. I have a set, and I tried just putting them on while I was installing. There was no contact with the tires and the wheel turned freely, but I didn't get a measurement.
What I did measure was a 19mm (3/4") gap between my 245-40 fronts on stock 8" rims (by finding a socket that just barely fit through the gap and measuring it's OD with a caliper). My 245's are exactly 1.5 inches (38mm) narrower at the bulge than my 275's, so I'd conclude that there's a net clearance of 1mm after adding the 3mm spacer and subtracting the 2mm difference in wheel offset.
Before I did the job, I read all the posts I could find and sent off a few PM's (thanks Reverend73!), and while they were really useful the project was a graphic example of the old adage "Experience is what you have just AFTER you needed it!".
To get it all down on paper when it was fresh, I wrote up three detailed DIY posts in the Tips and Tricks forum - one for getting the interior out (easy), one for the front suspension (sorta easy) and one for the rear (a lot of heavy work). What I tried to cover in the DIY's was the dumb questions that an amateur like me has that the pro's already know the answers to. I was alone last weekend when I did the job, so it really can be done solo!
Links:
Rear Deck: http://www.m5board.com/vbulletin/showthread.php?t=92491
Front Susp: http://www.m5board.com/vbulletin/showthread.php?t=92492
Rear Susp: http://www.m5board.com/vbulletin/showthread.php?t=92504
Cheers
JJ
Links:
Cheers
JJ
