Wow, straight from a South African magazine:
A Southern Cape family took photos of the three sensational Bugatti Veyrons. The Greeff family, Marianne, Derick and Annette, spotted these cars on the scenic coastal route between Betty's Bay and Gordon's Bay.
The photos also show that there are special stickers on the Veyrons, which read: "High speed test vehicle - Approved by Government." This indicates that the cars are in South Africa for test purposes.
The Veyrons was first spotted earlier this week on the Cape's West Coast and then a day later another Wheels24 reader saw them in the Overberg district on the N2 near Grabouw.
There are no badges on the three test vehicles but it is unmistakably Bugattis Veyrons.
The Bugatti Veyron is the hottest car in Volkswagen's arsenal. It features an 8-litre W16 (2xV8) muscle engine with a power output of 736kW at 6_000 rpm. Torque is a mighty 1250Nm.
The car has a top speed of 406km/h and accelerates from 0-300km/h in less than 14 seconds!
Layout
'W' engine with two V8 cylinder banks at a 90? included angle
Installed position
Mid-engine, longitudinal ahead of rear axle
Number of cylinders
16
Displacement
7 993 cm3
Bore x stroke
86 mm x 86 mm
Valves
64 (4 per cylinder)
Power output
736 kW at 6,000/min
Torque
1 250 Nm between 2 200 and 5 500/min
Compression ratio
9 to 1
Forced aspiration
four turbochargers
Driveline / wheels and tyres
Gearbox
Seven speeds, sequential-shift
Final drive
Permanent four-wheel drive
Wheels (alloy), front
235 x 520 A
Wheels (alloy), rear
325 x 540 A
Tyres, front
245-690 R 520 A
Tyres, rear
365-710 R 540 A
Body
Construction
Load-bearing carbon-fibre monocoque with aluminium frames at front and rear.
Combined aluminium and carbon fibre body panels, non-load bearing
Length
4 466 mm
Width
1 998 mm
Height
1 206 mm
Wheelbase
2 700 mm
Track, front
1 723 mm
Track, rear
1 632 mm
Performance
Top speed
406 km/h
Acceleration, 0 - 300 km/h
under 14 seconds
Layout
Installed position
Number of cylinders
16
Displacement
7 993 cm3
Bore x stroke
86 mm x 86 mm
Valves
64 (4 per cylinder)
Power output
736 kW at 6,000/min
Torque
Compression ratio
9 to 1
Forced aspiration
four turbochargers
Gearbox
Final drive
235 x 520 A
325 x 540 A
Tyres, front
245-690 R 520 A
Tyres, rear
365-710 R 540 A
Body
Construction
Length
4 466 mm
Width
1 998 mm
Height
1 206 mm
Wheelbase
2 700 mm
Track, front
1 723 mm
Track, rear
1 632 mm
Performance
Top speed
406 km/h
under 14 seconds
