Help on New TT-- Keeping M5 BTW - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > GTboard.com: Discuss other sportscars > Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com
Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com For Porsche owners and the upcomng BMW M5 competitor: the four-door Porsche Panamera. panameraboard.com
Old 17th July 2003, 07:28   #1
CaptainCurt
CaptainCurt's Avatar
Garage: 2001 Silverstone/Sport
I am deciding on a color for a new TT.
Probably Silver or Black, but there is a nice (Lapis) Blue with light gray interior (Has bling/bling chrome wheels on it) What do you guys think looks best?
Also, is the Nav worth it, or get an Aftermarket Nav system installed? Thanks for any thoughts.
Boy the M5 seems big/heavy after driving these............
CaptainCurtis the Flying Elvis:
Brand New Porsche 996TT (500 miles)
2001 Silverstone/Silverstone/Sport
Brand New Range Rover Spec. Ed. with 22" Bling Blings for Fun
Ordering Either new M5 or M6
CaptainCurt is offline   Reply With Quote
Old 17th July 2003, 08:57   #2
M5Kid
Garage: N/A
Well...
I personally think that black, silver or red are the three colors that you cannot go wrong on. I am not so sure about the blue and would stay away from the chrome wheels. I think that going aftermarket is the way to go with navigation, you will get a better system for the money. Companys such as Kenwood make very nice products that are a flip out headunit with navigation, mp3 and a power source for your stereo. If you go this route I would suggest upgrading your speakers also, to take advantage of the headunit. You could also buy a portable navigation unit, these units range from 150-500 dollars but can get even more expensive. In thirty minutes you could hardwire the unit into your car like a radar detector and it would work great!!
Hope this helps.
-Travis
M5Kid is offline   Reply With Quote
Old 17th July 2003, 11:32   #3
Jacob Lee
Jacob Lee's Avatar
Garage: 2001 M5 Black/Black
Unless the PCM unit with Nav that porsche provides is far inferior than that provided with BMW's 540/M5, I would never get an after market unit or portable for one single reason -
Built in wheel sensors designed to alleviate SA induced phasing of your calculated position. SA distortion is of course no longer routinely done ever since they signed the new law a couple years ago to stop the scrambling of non-military GPS units.
However, even without that, a single attenna GPS unit can be off by +/- 30 meters or so even for one considered "very good". You only get accuracy down to inches using industrial grade dual attenna GPS systems that perform trigonometic calculations to confirm your position. So 100 feet as the usual margin for error - if you try using a hand held Garmin unit, you'll see that when you are driving/walking on streets that are very close to each other in parallel, your position will phase back and forth sometimes from one street to the other.
With automotive GPS systems like BMW, I was told there was integration with wheel sensors so that the software would conclude despite a sudden shift in calculated position based on the GPS signal, that there was no way the vehicle could have just shifted horizontally by 100 feet. So as far as the map displayed to you, your calculated position is shown very steady.
Whether this is true or not I don't know, but it sure seems to make sense because despite the crazy nav routes our BMW systems sometimes shows, the displayed calculated position always stays steady, and I know for a fact that without some software extrapolation based on positional sensors, any hand held GPS unit will from time to time show you warping from one street to the other.
Jacob Lee is offline   Reply With Quote
Old 17th July 2003, 11:56   #4
HomerUK
HomerUK's Avatar
Garage: E60 M5 Indi Red
Will it be a new car? If so they've improved the PCM to PCM2 now. If what I've seen is right it now has a larger wide screen display, and they've imprved a few of the controls and menus.
I had PCM on a 2002 C4 and one thing I didn't like was the small screen and tha fact the phone needed a SIM inserted in a credit card size adapter, not sure if this has been addressed with PCM2. I also highly recommend the BOSE speakers, not sure if their standard on the TT.
Benifits of an aftermarket system would be the use of DVD, so more data is available and the access times are faster.
But whatever you decide I know you're going to have loads of fun with the TT...
HomerUK is offline   Reply With Quote
Old 17th July 2003, 16:43   #5
TCM
TCM's Avatar
Garage: 2001 BMW M5 Silverstone/Black luxury and 2001 M5 Jet Black/Black Luxury
Curt:
Congradulations on the 996tt, you will love it. Regarding the navagation, i would try to stick with factory options as much as possible as it helps resale and will integrate into the car much better then an aftermarket unit. Forgo the chrome wheels and look at some silver rims. The 996tt looks great in a wide variety of rims (HRE, Champion, Hamann, Techart, etc). Please let us know how you make out and please post some pictures !
T.C.
'01 Brushed Steel M5
front splitters
3.45 differential
'01 Silverstone M5- sold
SuperSprint:X-pipe
TCM is offline   Reply With Quote
Old 17th July 2003, 17:21   #6
DiscoFish
Garage: 2004 Mercedes-Benz SL500
Guards Red, or Speed Yellow.
DiscoFish is offline   Reply With Quote
Old 17th July 2003, 18:33   #7
greg
greg's Avatar
Garage: 2000 Anthracite
I have black. Best color to show off the car's curves. Pain in the butt to keep pretty.
I have seen lapis blue. It is a beautiful color. I would consider it for my next car.
Can't go wrong with silver - it is the most practical and the most popular. You may want it for this reason, or NOT want it for the same reason.
Red? Guaranteed more speeding tickets. Not for me.
greg is offline   Reply With Quote
Old 17th July 2003, 19:43   #8
M5Kid
Garage: N/A
Hey...
Jacob Lee- I had a hard time following your post but I gathered that you were saying portable units or aftermarket ones are not accurate inside of a car. Although I am not sure if the type of car would vary the results I know atleast two people who use them inside their car (both Toyota's) and it does VERY well.
greg- Are you going to buy another TT after you sell your black one? That is what I gathered from your post.
-Travis
Old 18th July 2003, 10:47   #9
Adam
Adam's Avatar
Garage: R32
Guards Red is the best imho...
all the best
adam
1995 Alpina B8 4.6 #10-(engine blew up. sold)
2001 BMW ///M5(sold)
2003 RUF R turbo
1990 RUF CTR
2006 VW Golf R32 DSG
2005 e60 M5 (sold)
2007 997 GT3 RS Carrara White
2008 Renault Clio 197
"You know it is kinda ironic, these old people are being kept alive by the organs of the young people they ran over" - Chief Clancy Wiggum
Adam is offline   Reply With Quote
Old 18th July 2003, 11:42   #10
Jacob Lee
Jacob Lee's Avatar
Re: Hey...
-Travis
Not at all. I did not say portable or aftermarket GPS units are not accurate inside of a car. That is a rather blanket statement meaningless without some context. Nor did I say or imply a portable or aftermarket unit can't be better than a car manufacturer's built in unit. That too is an open ended statement that can't be qualified without putting some context to what "accurate" is and what specific type of portable or aftermarket GPS unit one is talking about. However, assuming that "accurate" is based on the commonly accepted vernacular of the GPS industry, then yes - what I did say specifically say is that a single attenna unit, which is what most common hand held civilian GPS units are, gets "good" accuracy of about +/- 30 meters for calculated versus actual position.
Given this metric, a single attenna GPS unit, portable or otherwise, will not be "accurate" when travelling in areas where your plotted position is in close proximity to other potential plot positions such that the distance between these two points is less than the +/- accuracy of your unit because of the potential for your displayed position to shift based on signal interpretation from moment to moment. Unless of course that GPS unit has the advantage of "knowing" via input from other vehicle sensors that based on angle of direction, speed, time value between sensor data points and GPS calculated position points that the calculated position based on GPS signals are "wrong".
For example, if at t=0 the calculated position is at x1, y1, z1 coordinates, but at t=1 the calculated position is at x2, y2, z2 coordinates, and the total distance between these two spatial points is now 87 feet, your GPS unit would normally display your calculated position on the map as having moved between these two spatial points over whatever time period that t=0 and t=1 represents. However, if that GPS unit has the advantage of vehicle sensors that report that over the time period t=0 and t=1 the angle of direction (or even better an actual vector) did not deviate in a manner to make that position shift physically possible based on vector calculations, then a well programmed GPS unit would simply display your calculated position as having moved between your old position at t=0 and a new software corrected and extrapolated postion at t=1 based on a "best guess" of your last known position, angle of direction/vector, and time elapsed.
*-at this point, we could also start going into a couple chapters about how signal strength, frequency of sampling to update the GPS unit, # of GPS sattelites your unit sees in the visible horizon, etc., plays a part in just how your GPS unit is programmed to display your position blip against the known map reference, but let's just assume for the purpose of this discussion that both the portable/aftermarket units and manufacturer's installed units have the same coded logic tree.
Your friends in the Toyota with portable GPS units may consider the performance to be "very well". As noted above and repeating what I said earlier, in general GPS devices context, a civilian unit with only a single attenna is considered "good" if the +/- accuracy of actual versus plotted position is roughly 30 meters or less based on hardware capability (e.g. assuming the GPS signals are received from at least 3 orbitting GPS satellites without their signals deliberately scrambled or distorted as in the recent past when only military receivers received the "true" signal). So for your friends this might really be considered "very well" and in fact may actually out perform some auto manufacturer's built in GPS units if those built in units have a +/- accuracy far worse than your friends portables, or if the +/- is only slightly worse but the vehicle can not make up for that by software extrapolation from wheel and othe sensor data.
However, if your friends have a "really good" portable GPS unit with dual attennas, the usual +/- accuracy of one of these can be down to 5-10 meters depending on the distance between the two attennas. If your friends have one of these, then yes, even the usual auto manufacturer's built in units with wheel sensor integration would be hard pressed to match it, or only equal to it based on software correction, not actual raw capability of determining calculated versus actual positions.
Wooo tfung gone off deep end... EBMCS03 Off Topic Forum 4504 25th April 2011 22:04
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 12:24
BMW M5 culture over the net Rodrigo Feher E39 M5 and E52 Z8 Discussion 8 22nd December 2003 01:04
996 TT vs M5 observations... Jacob Lee Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com 16 23rd July 2003 06:24
