Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > GTboard.com: Discuss other sportscars > Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com
Porsche 911 Turbo and Porsche Panamera Forum | panameraboard.com For Porsche owners and the upcomng BMW M5 competitor: the four-door Porsche Panamera. panameraboard.com
Old 23rd April 2008, 04:46   #1
Gustav
Administrator
Gustav's Avatar
Porsche Cayenne Turbo S launched
Very nice!
PRESS RELEASE
Porsche reveals the new Cayenne Turbo S for the first time
Stuttgart/Beijing. Dr. Ing. h.c. F. Porsche AG, Stuttgart, has extended its third model line by the addition of the top of the range Cayenne Turbo S. The Turbo S, the most powerful Cayenne of them all, is driven by a 4.8 liter V8 engine with twin turbo forced induction, delivering 550 hp (404 kW).
The Turbo S is Porsche's response to the wishes of its customers. There is huge demand, especially in the new emerging markets of Eastern Europe and Asia, for exclusive sports-style SUVs with top quality physical handling dynamics. Despite the fact that Porsche has managed to give the new Turbo S even better drive performance than the regular Turbo model (500 hp / 368 kW), the fuel efficiency figures for the Turbo S are exactly the same as those for the Cayenne Turbo (as per the calculation methods stipulated under the New European Operating Cycle – NEFZ).
From the outside, the Turbo S can be recognized by its 21 inch SportPlus alloy wheels housed within its painted wheel arches and by a sports exhaust system with four tail pipes made from aluminum investment casting. The air intake grills and wheel arches are painted the same color as the car body. The new understated yet elegant "lava gray metallic" paint option is exclusive to the Turbo S.
All models of the Turbo S have a chassis which benefits from air suspension, not to mention suspension leveling and ride-height control, along with Porsche Active Suspension Management (PASM), which – once again as standard – is combined with Porsche Dynamic Chassis Control (PDCC) and Servotronic speed-sensitive variable power steering.
With the introduction of the Porsche Ceramic Composite Brake (PCCB) as an option, Porsche underscores its leading position as a provider of ultra durable brake disks made from carbon fiber ceramic composite. When the 2009 range is introduced, this high tech brake disk – originally developed for the motor sport sector – will become available for the first time in a sector other than the sports car sector, namely in the elite, top quality physical handling SUV sector. The front axle ceramic disks are 410 mm in diameter, whereas the rear axle disks are 370 mm in diameter. Deceleration takes place via six-piston calipers at the front and four-piston calipers at the rear. The PCCB is available as an option on other Cayenne models such as the Cayenne S, GTS and Turbo, subject to wheel sizes of at least 20 inches.
The high quality character of the new Cayenne top-of-the range Turbo S is emphasized by the standard equipment of the interior, the front sports seat with Comfort Memory Package, rear seating with individual seat contours, aluminum door panels showing the name plate together with leather upholstery in two exclusive dual-color combinations (black / Havana and black / steel gray) plus a leather steering wheel with padded center.
The latest generation of Porsche Communication Multimedia System Management (PCM) inclusive of navigation module with hard drive provides a full range of new, easily accessed functions actuated via a touch-screen. As with all other Cayenne models, the Cayenne Turbo S also comes with the option of voice actuation with full word recognition for navigation system destinations, universal audio interface (with MP3 connection), cell phone link-up via Bluetooth and a TV module for both analog and digital terrestrial signals. Offered as standard, the BOSEŽ Surround Sound System with 14 speakers features enhanced 410 Watt output and is now capable of reproducing music from audio and video DVDs in 5.1 Discrete Surround Format.
The Turbo S's enhanced performance relative to that of the regular Turbo model is due to its modified exhaust system and improvements in engine control. In addition to the performance improvements, there has also been an increase in maximum torque by 50 Nm to 750 Nm within an engine speed range of 2,250 rpm to 4,500 rpm.
The Porsche Cayenne Turbo S can accelerate from zero to 100 km/h in 4.8 seconds and its top speed is 280 km/h. The Turbo S will be introduced into the market as from August 2008. The international basis price is EUR 111,400.
Technical data
Engine: V8 with two parallel exhaust turbo loaders
Fuel injection: direct fuel injection (DFI)
Displacement: 4,806 cm3 (293.3 cu in)
Bore: 96 mm (3.78 in)
Stroke: 83 mm (3.27 in)
Compression ratio: 10.5:1
Max. power output: 404 kW (550 hp) at 6,000 rpm
Max. torque: 750 Nm from 2,250 rpm to 4,500 rpm
Gearbox: Six-speed Tiptronic S converter automatic
Transmission: Permanent all-wheel drive Porsche Traction Management (PTM) with transfer gearshift
All-wheel moment distribution: 38 % : 62 %
(Basic distribution front/rear)
Chassis: Independent suspension – front: via large basis double wishbones; rear: multi-link suspension; air suspension with suspension leveling and ride-height control, including Porsche Active Suspension Management (PASM) and Porsche Dynamic Chassis Control (PDCC)
Brakes: Front: six-piston aluminum monoblock fixed caliper brakes together with two-part internally ventilated brake disks with diameter of 380 mm; rear: four-piston aluminum monoblock brake disks together with internally ventilated brake disks with diameter of 358 mm
Wheels: 10 J x 21
Tires: 295/35 R 21
Steering: Servotronic speed-sensitive power steering
basic weight: 2,355 kg (DIN)
Permissible total weight: 3,080 kg
Acceleration: 0-100 km/h in 4.8 sec, 0-60 mph in 4.7 sec
Max. speed: 280 km/h (174.0 mph)
Fuel consumption: 14.9 l/100 km (combined, as per NEFZ), 18.1 mpg (combined)
Emissions: C02 358 g/km (combined)
Pollutant class: EURO 4
http://www.autoblog.com/2008/04/20/b...yenne-turbo-s/
Gustav is offline
Old 23rd April 2008, 08:41   #2
760Lifan
760Lifan's Avatar
Garage: 2006 M5 Black Sapphire Metallic
HOOOOLY SMOKE!!
Now this is by far the best SUV I've ever seen. Now even with Bluetooth and PCCB brakes.
I was wondering if we would get the upgraded performance-kit (+40hp) on the regular Cayenne Turbo in the US as well - I guess THIS car makes this question irrelevant!
Great post, Gustav!
2006 BMW 760Li, Black Sapphire Metallic, Natural Brown, All Options
2006 BMW M5, Black Sapphire Metallic, Silverstone, All Options
2006 BMW X5 4.8is, Black Sapphire Metallic, Cream Beige, All Options
760Lifan is offline
Old 24th April 2008, 01:01   #3
Gustav
Administrator
Gustav's Avatar
Thanks1 Yesi it os the best SUV except the Gembalal Cayenne Turo GT750
Gustav is offline
Wish m5board.com members participating in Gumball 2005 good luck! Gustav Gumball 3000 Forum 2 20th May 2005 07:52
Wish m5board.com members participating in Gumball 2005 good luck! Gustav E39 M5 and E52 Z8 Discussion 0 16th May 2005 00:15
An excellent article of the Lamborghini Gallardo vs Porsche Turbo "X50" Black M5 GTBoard.com: General Sportscars 1 6th July 2004 13:59
Cayenne Driving Experience KRM GTBoard.com: General Sportscars 0 13th August 2003 10:01
Porsche Cayenne - pricing/model info inside AJ GTBoard.com: General Sportscars 0 5th August 2002 20:48
Page generated in 0.15365 seconds with 11 queries
