• Latest threads
    • Custom feed
      • Updates
        Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > Off Topic Forum
        Off Topic Forum This is the place for mature discussions not necessarily related to cars. This is however also moderated and only registred members are allowed to post.
        Old 20th October 2006, 09:40   #1 (permalink)
        AlLmItEeM5
        AlLmItEeM5's Avatar
        Send a message via AIM to AlLmItEeM5
        Spacers required?
        i've heard from people with e39 that have 19"s required spacers. is that true?
        AlLmItEeM5 is offline
        Old 21st October 2006, 08:42   #2 (permalink)
        ard
        ard's Avatar
        No. Not "required".
        You need to research the concept of 'wheel offset'.... You can get a 19" rim that is 9.5" wide with the right bolt pattern and depending on the OFFSET it will fit or rub. Offset it the degree to which the CENTER of the tread is 'offset' to the face of the hub where the wheel mounts.
        When you buy wheels you need to specify the diameter, width, bolt pattern, hub bore AND OFFSET!
        A
        ard is offline
        [IMG] code is Off
        Forum Jump
        Spacers on OEM wheels Snogard E39 M5 and E52 Z8 Discussion 18 30th June 2006 09:36
        H&R spacers rusting?? Wolverine E60 M5 and E61 M5 Touring Discussion 4 19th June 2006 00:00
        The use of wheel spacers on our car's, Is it doable or a no-no ? FAST 5 E39 M5 and E52 Z8 Discussion 6 9th February 2005 12:25
        Spacers with 18's ? Carrera2RS E39 M5 and E52 Z8 Discussion 2 16th September 2004 17:33
        Brembo 355mm front brakes only require 3mm spacers - not 5mm. DZeckhausen E39 M5 and E52 Z8 Discussion 14 14th March 2004 19:58
        Page generated in 0.14121 seconds with 11 queries
