Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > Off Topic Forum
Off Topic Forum This is the place for mature discussions not necessarily related to cars. This is however also moderated and only registred members are allowed to post. No religion and no vicious attacks.
Closed Thread
LinkBack Thread Tools Search this Thread Rating: Thread Rating: 4 votes, 3.00 average. Display Modes
Old 23rd June 2005, 23:25   #211
bbloch1114
bbloch1114's Avatar
Garage: 2006 M5 Saphire Black
Re: Living with a Supercharged M5 from Discovery Automotive
Originally Posted by jimmyz2
I am glad there is light at the end of the tunnel for you and you are getting things worked out.Regarding the aftercooler doesn't MB also place their aftercooler there?I did not know you were using a piggyback system with extra injectors.I thought RMS burns a custom chip,unless Discovery took it out?
The system is the same RMS or DA -- and yes, they both played with the chip. The second set of injectors all fire at once -- sloppy.
Thanks for the encouragement.
Current M5:
2006 E60
Saphire Black
Silverstone Merino Full Leather
12mm front H&R spacers 15mm rears
Previous M5 (sold to DoctorV8):
2001 E39
653 HP/510 lb/ft
Vortec Supercharger
Active Autowerke Air-to-Air Intercooler
Aquamist Water Injection
Supersprint Headers
TubiStyle Exhaust
Koala Motorsports 3.15 ring & pinion
4-wheel Brembos
KW Varient 3 Suspension
Dinan Mono-Ball lower control arm mounts
Dinan Wheels -- powercoated to match OEM wheels
Dinan Rear Subframe reinforcement (from Dinan S3)
bbloch1114 is offline
Old 10th August 2005, 09:39   #212
lwebb12
lwebb12's Avatar
Garage: Oxford Green Metallic 2000 M5
Send a message via AIM to lwebb12 Send a message via Yahoo to lwebb12
Do you have any updates?
UUC Stage 3 clutch. Euro storage bin mod. Beastpower Rear swaybar brackets. Euro first aid kit and fire extinguisher.
lwebb12 is offline
Old 10th August 2005, 16:11   #213
bbloch1114
bbloch1114's Avatar
Only that the car is at AA. The problems of check engine and so on are fixed -- unfortunately, the original Intercooler design did not have enough coolant in the system (only 1.25 gallons) so the car would get heat-soak really fast and badly and have no power.
At Vortec's recommendation, we increased the capacity to 3.25 gallons by adding a "needed" -- according to Votec -- resoviour. Also, I am having vents installed in the hood to dissapate heat.
When I get it back it may finally be what it was supposed to be. Of course, now that this whole thing has taken so long and cost so much money, I just want to sell the car when it returns and I will. What a HUGE waste of money and time. Good luck to all of you that choose to go this route -- you will be sorry I bet, sorry and down an extra $50K-$60K. If you know anybody who wants to buy it, send me a note in a few weeks -- that's when I will have the car back.
Old 10th August 2005, 17:48   #214
jimmyz2
Banned
Garage: 1995 540i 4.4L supercharged
Bill,I am truely sorry it has not turned out well for you with your S/C project.I wonder if the Dinan guys are experiencing any problems similar to yours.Anyways,good luck.
jimmyz2 is offline
Old 10th August 2005, 18:09   #215
bbloch1114
bbloch1114's Avatar
Thanks Jimmy -- actually, I'm Bryan, not Bill. I doubt the Dinan version will have any of the same problems once delivered -- they have way more money than DA, AA or RMS and they have a direct and open relationship with BMW. There really can't be any comparison to hat setup.
Old 10th August 2005, 20:55   #216
lwebb12
lwebb12's Avatar
That is a shame.
lwebb12 is offline
Old 11th August 2005, 00:42   #217
jimmyz2
Banned
Sorry Bryan.I knew your first name started with a "B".
jimmyz2 is offline
Old 16th August 2005, 02:02   #218
M5Racer
M5Racer's Avatar
Garage: BMW M5 '02
Hi All, has anyone considered going with ESS Tuning - I've spoke with them and they are working on releasing a Super Charger for e39 M5.
www.esstuning.com
Let me know.
Thanks.
Originally Posted by shadowman
That was a good comment.
As I recall the situation with Dinan and dyno number was solicited verus attainable. I shared that we saw a variety of numbers during the tuning process all of which were shared and then the resulting numbers which were not the peak numbers, rather those that the car left with.
I would suspect that if the car was placed back on the same dyno with similar conditions the original numbers would reproduced.
My feelings about dyno numbers has always remained the same, interesting but little more.
Shadowman
M5Racer is offline
Old 16th August 2005, 17:02   #219
bbloch1114
bbloch1114's Avatar
www.esstuning.com
Let me know.
Thanks.
I went to thier web iste -- it seems like a kit they ship to you. that is too far away for me to buy an out of the box kit. I also con't recall it having a heat exchanger or any kin dof an intercooler set up. I'm not positive, but I don't remember seeing one. And the M5 needs one with a supercharger. In fact, it almost needs one with normal aspiration because of the easily generated heat soak.
Wait a littel longer for the AA kit -- it too will be out of a box, but they use a simple air-to-air system and they will use a simple injectors setup -- eliminating the need for a piggyback computer and they do away with two other "black boxes" that in the past were needed to fool the mass airflow sensors. AA is now controlling the entire system with the stock DME because they have the know-how to modify the stock ECM. When I got my car back from both RMS and DA, it needed these three additional control units plus 8 additional injectors that fired all-at-once to add the fuel the the stock injecotrs could not supply. Now I am going to end up with one set of bigger injectors and one ECM -- the stock DME. To me, that is a much simpler and accurate set up with far less to go wrong. Plus, now if I lost the injector the stock DME would imeedately react and shut off fuel. With my current setup, I would only know if the secondary injectors went when the engine went.
Old 16th August 2005, 23:00   #220
de Witt
de Witt's Avatar
Garage: 1988 M5 (x2) 1991 M5 2008 M5
Send a message via AIM to de Witt
That is such shoddy design. Piggyback ECUs are garbage. Plus, like you state, the engine could go lean in an instant, which is a big problem with piggyback ECUs. I installed a Autronic ECU on my E28 M5, but looked at piggybacks like Split Second, and those are such trash. The possibility for the mixture to go lean is just way too high.
{o,o}
|)__)
The E28 M5 FAQ
The E34 M5 FAQ
The E24 M6/M635CSi FAQ
de Witt is offline
Closed Thread
German AMS magazine tests M5 suspension kits lofstrom E39 M5 and E52 Z8 Discussion 25 11th April 2008 13:24
Getting Nostalgic, E39 M5 rumours from bmwm5.com back in '97! Gustav E60 M5 and E61 M5 Touring Discussion 12 18th February 2008 07:03
e39 m5 is the undisputed champ cebu E39 M5 and E52 Z8 Discussion 7 1st February 2008 07:28
Press Release 1: World premiere of the new BMW M5 (summary of all press releases) Gustav Most Memorable Threads' 0 4th July 2004 22:13
Guys, BMWNA is asking for opinions on the E39 M5 messageboard at the Roadfly site.... FAST 5 E39 M5 and E52 Z8 Discussion 16 11th March 2004 02:49
Page generated in 0.21442 seconds with 12 queries
