Nail in tire ... AGAIN!!!!! - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > Off Topic Forum
Off Topic Forum This is the place for mature discussions not necessarily related to cars. This is however also moderated and only registered members are allowed to post. No religion and no vicious attacks.
Old 5th May 2003, 04:31   #1
kevin034
kevin034's Avatar
Garage: 2002 BMW E46 M3 Carbon Black
While many of you may claim that your Ms are magnets for chicks, I can officially tell you guys that my M3 is a magnet for nails. Especially the rear passenger tire, the wheel must be made out of magnet or something like that. Oh, if you are in the PA area and don't want to get nails in your tires, just look for me, the sucker in the CB M3 and follow, my tire will pick up all the nails so you don't get any.
Ok, the situation, (not a nail) but a hex-headed screw-in bolt about .5 inches in diameter is stuck in the edge of the sidewall and the contact surface of the tire. I put soap over it and no bubbles form at all for the measured 3 minutes.
Decision ...
1. Pull out the bolt, test w/ soap again, if no bubbles (no leak), just ignore it. There's about 5000-6000 miles left on the tire.
2. Pull out the bolt, test w/ soap again, make sure there are no bubbles. Order 2 new sets of rears and ride out the damaged tire until they get here.
3. Keep the bolt in the wheel and just ignore it.
4. Keep the bolt in the wheel, order the new rear tires, and ride out the damaged tire until the new tires get here.
What should I do?
Kevin
2002 E46/// M3 Carbon Black / Grey
SMGII / 19" M Wheels / H&K Stereo / Navi. System / Bi-Xenon Lights
35% Tint / Valentine 1 / 6000K D2S Lights / Euro Floating Rotors
StopTech Brake Lines / Axxis Ultimate Pads / Eisenmann Titanium Exhaust
kevin034 is offline   Reply With Quote
nail in tire kiwi M & M E39 M5 and E52 Z8 Discussion 4 9th September 2003 01:49
tire wear 40/40 psi M'nd E39 M5 and E52 Z8 Discussion 25 12th June 2003 06:30
Tuning with tire temperatures Bart Carter M5 E39 and E60 tips & tricks 3 18th March 2003 16:16
Amazing new patch-less, plug-less tire repair system!!! ivory1 E39 M5 and E52 Z8 Discussion 14 17th June 2002 23:11
M5 wheel and tire dimension survey stever E39 M5 and E52 Z8 Discussion 0 14th April 2001 23:21
