• Latest threads
    • Custom feed
      • Updates
        Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > Off Topic Forum
        Off Topic Forum This is the place for mature discussions not necessarily related to cars. This is however also moderated and only registred members are allowed to post.
        Old 1st May 2003, 10:44   #1 (permalink)
        dmcgibbo
        dmcgibbo's Avatar
        PC HELP! How do I restore/reformat WinXP and my drive?
        I have PowerQuest Partition Magic and was resizing my partitions but during the resize there was an error and my PC went bezerk. I used a Windows restore disk and somehow got to log back onto Windows and restore the file structure. However, there is still a partition problem on the drive and the PC runs slower and disk cleanup won't run among other problems. I purchased an external drive and backed up everything onto it just in case, but I have been using my computer as if nothing happened b/c I've been too lazy to start over and wipe it clean and reinstall everything.
        OK - now I have the time to reformat/restore everything so that it runs more smoothly and so the partitions aren't corrupted. However, how do I do this? Does putting in the WinXP recovery CD do it or do I need to do something with Partition Magic first (resize/delete/reformat the partitions) or should I somehow wipe the drive to a clean slate and start from scratch or what? If I just try to restore Windows and reinstall it, I don't want it to reinstall on a drive w/ corrupted partitions you know? But then again, the file structure was a problem B/C of WinXP so maybe recovering it would fix the problem. Or maybe I should use Partition Magic to redo the same thing that caused the problem before so the partitions are ok or I have no idea. I've never done this before, and I don't know how having 2 partitions affects a restore (repartition first, leave as is, wipe entire drive, delete partitions install WinXP and then re-partition or what).
        Any advice/help you can give is greatly appreciated. I wrote down the programs I still need so I can try to find all the cd's to reinstall them. I would just take a drive image or copy the drive but then I'd just be copying the corrupted partitions. What is the best way to fix my computer so that it runs like new? I'm thinking I'll just stick the WinXP recovery CD that IBM gave me and go that route but I bet there are confusing options in it...
        dmcgibbo is offline
        Old 2nd May 2003, 07:03   #2 (permalink)
        X5Boston
        X5Boston's Avatar
        Most systems nowadays do not come with complete versions of OSes. As you stated, you have a recovery CD. Using it will bring the system back to the same state as it came out of the factory. The restore CD will handle all partitioning and transfer of data. Those CDs basically do a bit for bit binary transfer of information to the hard drive.
        The process is actually straight forward. As usual, there are about twenty "Are you sure you want to permanantly wipe out everything on your drive?" warnings.
        2002 X5 4.6is Silver/Black (AKA M4 3/4)
        2007 X5 4.8i Gray/Beige (On Order)
        X5Boston is offline
        [IMG] code is Off
        Forum Jump
        Page generated in 0.15293 seconds with 10 queries
