Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > Off Topic Forum
Off Topic Forum This is the place for mature discussions not necessarily related to cars. This is however also moderated and only registred members are allowed to post. No religion and no vicious attacks.
Old 7th June 2009, 08:58   #11
Myke951
Myke951's Avatar
Garage: 944 Turbo White
Send a message via AIM to Myke951
black with metal flakes in silver painted stripes...
2004 Mini Cooper S: Alta supercharger 15% pulley upgrade, Dinan cold-air intake, Skunk2 header back exhaust, RMW CUSTOM TUNE, Alta oil catch can, OMP Strut brace, Eibach pro-kit springs, H-Sport camber links, 19mm Rear sway bar w/ adj. end links, 18 in. Breyton mini magics, 6lbs lighter crank pulley, polyeurathane tranny and engine bushings, wheel Studs, Wilwood BBK... More to come soon!
RIP=White 944 turbo: KKK K-27/6 turbo, upgraded intercooler, Lindsey Racing hardpipes, Autothority MAF, B&B exhaust with 4.5" oval tip, Siemens #55 fuel injectors, Lindsey Racing MaxHP custom Chip set, 3 bar fuel pressure regulator, Re-worked head and slightly overbored pistons, Spec Lightened 6 puck stage 3 clutch, Quaif torque biase differential, Apexi AVC Type-R Electronic boost controller, HKS type-1 turbo timer, Shimmed wastegate, Champion Motorsports adj. bypass valve, Weltmeister front and rear sway bars, Weltmeister strut tower brace, Koni adj. "yellows", unknown springs, Turbo Twist rims, Kumho Ecsta Supra tires... And a couple of more unknown mods...
Myke951 is offline
Old 24th August 2009, 04:49   #12
G ///McGregor K
G ///McGregor K's Avatar
Garage: '08 M5 Space Gray
A little update. Just got back into town about a week ago after spending the summer hanging out in CA with Baller and Myke. Got a few things done including putting in a new windshield, bolting in some racing seats and 4 point harnesses and I ordered a new motor. It should be in by next week sometime. I went with a 540 cubic inch Chevy big block with 677hp and 582tq, aluminum heads, full stainless roller rockers, forged crank. In case anyone is interested in the specs of the motor and its internals, here they are:
ffice:smarttags" name="place"> Machine Work
  • 502 4 BOLT BLOCK NEW GEN 6 WITH FUEL PUMP BOSS OIL COOLER PROVISIONS UPGRADE FROM 08 MODEL
  • align bore and or check for run out.full race clearancing
  • Bore Torque Plate Hone ... Torque Plate Gives True Finish
  • Dynamic balance assembly..
  • File fit rings - blue print clearance...
  • Install cam bearings - freeze plugs...
  • Port blue print cylinder heads...
  • Final assemble full rotating and top end
    • Parts including final torque - clearance - and geometry of all parts...
All new Performance Internal Parts
  • JE SRP FORGED pistons 10.7 to 1 piston set[ PUMP GAS OK]
  • Childs & Albert - zz gapdura Moly File Fit Rings... [provides the ultimate in ring sealing making more power!!
  • EAGLE STROKER STEEL CRANK...
  • EAGLE 4340 FORGED RODS LONGER .200 WITH FLOATED PINS AND ARP BOLTS
  • Clevite- -bearings tri metal 77 - rod and main...
  • custom hi output cam lifter set ..
  • Cloyes - true roller set...
  • Comp - cams cam locks...
  • FULL RACE xe chrome moly pushrods ULTRA ALLOY 080 WALLS NO FLEX UPGRADE FROM 08
  • Dyna gear race - oil pump...
  • Dyna gear - pickup...
  • ARP - steel drive...
  • After market - oil pan. baffeld 7 qt
  • After market - timing cover... NEW GEN 6 ALUMINUM POLISHED UPGRADE FROM 08
  • pioneer/arp - head bolts...
  • ARP/ - rocker studs 7/16... PRO SERIES UPGRADE FROM 08
  • Fel Pro RACE MARINE blue - gasket sets...
Power Making Featured Parts PRO ALUMINUM 325 RUNNER RECTANGLE PORT ALL NEW PORTED HUGE FLOW STAINLESS VALVES STAGE 1 PORT WORK MAJOR POWER GAINS 2.25 VALVE 1.90...WITH 540 CU IN
    • Features - - -severe duty STAINLESS 2.25/1.90 valves plus ... 1.55 springs 10 degree super locks comp cam parts..good porting..7/16studs guide plates.gasket match p.c seals.chrome moly retainers.. YOU NEED THIS SIZE VALVE TO MAKE THE POWER ALONG WITH THE CAM!!
  • hi perfromance STAINLESS FULL ROLLER rockers-1.7 ratio... UPGRADE 08 MODEL
  • custom series- -muscle car cam RADICAL IDLE.MAJOR LOW RPM TORQUE WITH EXTENDED RPM RANGE[1800 THRU 6000]
  • Features - 108 center line 618 - 618 lift corrected 1.7 ratio = . 246/246 dur @ 050 awesome power range 3000 stall. lopey muscle car idle. 100% streetable and will run vacum access VAC CAN SUGGESTED
The place I got it from had a bunch of inventory on hand so they needed to get rid of some stuff so I got a really good deal. It is going to come with a 950 dominator carb and it's turnkey, so I'll just drop it in. I'm going to pair it with a Turbo 400 tranny (which, from what I've heard were overbuilt in the first place and should be able to handle all the power fine).
I was thinking pretty hard about rebuilding the Pontiac 455 motor currently in it, but it just didn't make sense because of their propensity for catastrophic failure since they inherently weaker than their Chevy counterparts (454/502). It should be a fun motor to have in this car. I'll add some pics of it in the car when I get it in within the next 3 weeks or so.
2008 Space Gray/Black Full Merino Leather/Alum. trim
Loaded - every option (minus heated steering wheel)
Interior:Hardwired Valentine One with Concealed Display, Blinder Xtreme M25 (J16) Laser Jammer, Bimmian Interior Xenon Lighting Kit and ///M Racing Pedals
Exterior: Hartge Front Spoiler Lip, Hartge Rear Diffuser, Vorsteiner Vented and Domed Hood (Double-Sided CF), Hamann Roof Spoiler, H&R Springs and 15% Tint
"Performance": ASR Cold Air Intake, RPI GT Section 3 Muffler, Custom Fabbed Straight-Pipe Section I, Evosport Power Pulley and Hybrid Rear Badge
G ///McGregor K is offline
Old 24th August 2009, 05:43   #13
Myke951
Myke951's Avatar
Damn.... dont kill yourself!
Myke951 is offline
Old 24th August 2009, 06:39   #14
AFC1
AFC1's Avatar
Garage: 2004 M3 Convertible 6 Speed-Silver Gray/Gray
Wow that sounds like an incredible car! Post some pics when u get a chance.
afc1
AFC1 is offline
Old 30th August 2009, 15:59   #15
KWP
KWP's Avatar
Garage: Carbon Black M5 & Nassau Blue C5 Corvette & 2008 X5
I think a digital dash would be cool since you're not keeping it all original. My brother has one in his 74 Caprice and it looks OK.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." - Benjamin Franklin
2002 Carbon Black ///M5
Eisenmann exhaust
Beastpower swaybar brackets
Kelleners Pedals
Bimmian oil cap
Bimmian Matte Black Kidney Grilles
xenon-type foglights
2008 Black Sapphire Metallic X5 3.0
KWP is offline
Old 30th August 2009, 17:19   #16
Infamous Q
Infamous Q's Avatar
Garage: 2002 BMW M5 Carbon Black
Sales Feedback: (3)
If I ever come through SC I'm going to have to stop and look at your beast that thing is sexy!!!!!
"Forgiveness is between them and God. It's my job to arrange the meeting" -John Creasy
Untouchable Q
M6 Rims
CF Interior
Blacked Out Grills
Angel iBright Eyes
Slotted/Drilled Brake Rotors
Dice Ipod kit
Alcantara Steering Wheel
Coming Very Soon:
Short Shifter Kit
Infamous Q is offline
Old 30th August 2009, 17:45   #17
G ///McGregor K
Haha thanks, you're welcome here anytime
Old 30th August 2009, 18:37   #18
Cosmos
Cosmos's Avatar
Garage: has lots of porn
Sales Feedback: (3)
I really cant stress enough a few things.
1) You should pull ALL the carpet up and see what else has rust on it.
2) Make sure chassis is still cool. Frame rails and other bits, again look for what I call "rust holding hands". Basically the only thing keeping certain parts together is rust and rust,
3) Make sure all mounting points and rubber stuff has not cracked on vital high stress areas.
4) Brakes, Brakes, Brakes!!!!! Upgrade them. Do lines and check the booster and the hoses as well.
5) Suspension, (please see above)
That car is BAD AZZ!! I really like it.
"Motion does not equal progress"...Cos
Malo periculosam libertatem quam quietum servitium...
Cosmos is offline
The Following User Says Thank You to Cosmos For This Useful Post:
G ///McGregor K (30th August 2009)
Old 30th August 2009, 20:06   #19
G ///McGregor K
Thanks Cos -- definitely good advice. I've got a Hotchkiss Total Vehicle Suspension System I'm gonna put on her as well as a Baer BBK. I'll make sure all the structural integrity hasn't been compromised by any rust for sure!
Old 3rd November 2009, 02:59   #20
G ///McGregor K
Update:
So I've got the car in the shop having the motor installed. Just waiting for the ceramic coated headers, subframe connectors and Flowmaster Mufflers to come in. I decided to pair the motor with a Turbo 400 with a 3000 stall. I expect the car to be driveable within the next 10 days and will post back once I get her back.
On a side note, I will be selling the old 455 motor paired to the Turbo 350 with a shift kit
Numbers of interest are as follows
Date Code: K092
Casting Number: 485428
I do have other information on the engine if anyone is interested PM me
My New Project... G ///McGregor K GTBoard.com: General Sportscars 36 5th November 2009 22:05
Project Calypso - E34 M5 3.6 Track Day Project FinalEditionE34M5 E34 M5 Discussion 80 23rd April 2009 04:27
new project ;) Payam972 E39 M5 and E52 Z8 Discussion 20 4th April 2009 09:31
E60 M5 S85 V10 CAD Project e31bimmerman E60 M5 and E61 M5 Touring Discussion 37 13th December 2006 04:45
project using the s62 Quadcammer E39 M5 and E52 Z8 Discussion 12 12th September 2004 22:20
Page generated in 0.27201 seconds with 12 queries
