Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > Most Memorable Threads'
Most Memorable Threads' Here we gathered some of the most enjoyable or informative posts since March 2000. You cannot post here, only read and vote.
Old 20th May 2002, 18:46   #1
Apples
Apples's Avatar
Garage: 2000 M5 Blue
My thoughts and some dyno results OEM Vs Nowack...long version
Here are some of the answers, but maybe not all of them to the power questions I've had with Nowack since l had my M5 converted late last year, and some of them resolved????
I emailed over to them some of the dyno read-outs l had got in Orlando just a few weeks back. I called them a few days later, as to give them time to have a good look at my findings !!!
So to draw a picture, my base numbers before the conversion, were around 345 SAE RWHP and 335 lbft for torque.
My new numbers now after the conversion are 385 SAE rwhp and338 lb....so a plus 40 hp gain and less torque then what it had before the conversion..... l had to ask myself.. WTF as Nowacks claims are miles higher then those numbers even if they were converted to their larger DIN format of power measurement numbers.
It's so easy to think you've been had, when you see results like that.
When l emailed them the dyno sheet read outs I converted them into their "DIN" hp/ps format for their ease of use. Our SAE hp rating is just a bit lower then DIN in hp & tq numbers.
So to look at all numbers in DIN from now on will make it just a bit easier to compare to Nowacks tested results. So then in DIN all l could muster from the conversion was a converted and corrected max of 400rwhp DIN...(our U.S 385 rwhp SAE).
I did manage to find a max of 408 rwhp DIN using some leaf blowers (leaf hogs to be exact) in each ram duct......yes its very primitive, but it was the only way l could try and recreate (cheat), and to see if some sort of forced air flow could produce more power over normal dyno testing procedures, and to even try and get close to Nowacks 470 rwhp DIN claims??.
The blowers did give some extra torque.. 20+lbs in the middle rpm's... 4,000 - 5,500 rpm to a high of 353 DIN @ around 5,000rpm (+12 ft pound over OEM), Torque on the "leaf blown" run Vs and the "normal" tested run, then began to taper back towards each other from 5,500 - 7,000rpm. The "leaf blown" HP numbers only started to climb above the "normal" converted runs, at around 4,500rpm and stayed that way with ease till 7,500 rpm.
So l was not to count the "Leaf blower" tests as any real break through in gaining much power over stationary "normal" testing. The test was a bit more of a cheap experiment, but l think it was a very worth while one. l was really expecting the "blowers" to have made more power then they did though???.
So to see the new maximum peak torque number being 5 lbft LOWER then the old OEM figure, was one hell of a "scratch your head deal" The torque curve was much more up and down, and most of the time spent it climbing and falling, and always under the very flat OEM torque curve readings of the stock M5 till around 5,000rpm.
This lower torque maximum in the Nowack would/could be explained as the whole exhaust system is larger in diameter and the back pressure being cut by half, could be the main contributor to that, but l'm not sure... what do ya think ???.
Torque on the N500 (normal testing) touches almost it's high point at 3,200rpm (330lb) very briefly but gets to it's actual peak of (338lb) @ 5,000 to 5,000. That might sound good but it has to fall 25lb in between to 305ft @4,000rpm to climb back up above 5,000rpm.
Torque only begins to flatten out from 4,500 - 6,000 RPM and the N500 has as much torque @ 6,000 rpm as the stock M5 has @ 5,000rpm, but thats to be expected as HP is still on the climb so torque is very relevant in that aspect.
On the HP front the Nowacked M5 makes less power on a dyno from 3,200 - 5,000rpm...(there's that low dipping patch again) then the OEM....about 25Hp @4,000 (low point).much like the torque curve is low at the same points, but by that 4,000 rpm point it starts to fly up and crashes through the stock tests by 5,000rpm.
So lets get to the Apples Vs Nowack HP difference.....
I found out that the HP results Nowack got for my engine was NOT from what we call "normal" dyno testing procedures.....shock horror.
I was told they have a very $$ and complex air flow system in their shop that supplies large amounts of air (not sure of what speed) to the engine through it's full maximum rpm range. This seems to make sense, and more then likely explains why their numbers are so high, and mine to be so low as a comparison. But l can't work out how they still said they got 470 rwhp DIN form my engine.
They said that when the M5 was first in it's R&D stages, they were able to read (software) the amount air flowing through the system at any given time and speed, and as speeds increased so to would the amount of air flow and the related pressure in and out of the system. The OEM ECU wasn't really built to handle the internal changes and mixed with the new air parameters they say they could add 100hp. With this air being rammed into the engine and this being very important as speeds increased well over 100mph) it became very important for them to take advantage of this "ram effect" and change the amount of fuel being suppled at any given time. But really, the only way your going to get this 500+hp claim is only going to be possible in 5th or 6th gear at full tilt on a open road.
So this "expensive" air flow system they have in the shop is basically trying to recreate on road going conditions. I don't know how good, or accurate it is, but they're very confident that my engine creates well over 500HP, but to see all of that l would need to be doing 180 + mph. Thats not very relevant for our very slow open road speed limits in the US....... Lucky dam Germans.
What l don't get is what sort of power would the engine be making at say 7,000rpm in 3rd and 4th, as the air speed into the engine is quite a bit lower???
Looking back l guess it makes some sense, that it would be near impossible to get an extra 100hp out of an already M Powered BMW engine, and for it t be produced in a street able form, and from "normal" dyno testing procedures.
It seems and looks like false advertising to me for them to say that their M5 can make 500+hp. There's no mention at all in any promotional info that it produces it any different to the norm, or the way BMW states their 400hp.
Apples to Apples would be fair don't you think.......sorry l had to say that.
So my Nowacked engine probably has around a real 430 - 450 HP SAE at the engine, and as I've been told that number grows as speeds increase......and don't get me wrong l'm not complaining a 100%, but it's just that l wish l had known this all before the fact. This car is really only to be fully enjoyed on Germany's unrestricted roads.... .Dam that sounds like fun.
If you had a stock M5...but it's speed unlimited, and my M5 side by side and raced them from 2,000rpm in 5th till around 7,000rpm) l would say the stock M5 would pull out a gap on mine till around 100mph (160kph) mark, then the N500 would begin to make ground as quick as the stock M5 pulled away below 100mph (160kph) The effect of the rammed air at those speeds, mixed with the Vanos kicking in at 4,000+rpm is really how it takes it's full affect over a stock M5. If driven hard from a stand still how muck quicker would the "N500 converted" car be over a stock one from 60 to100, to 150 mph+...I don't know??? Just my opinion though......and l maybe totally wrong.
I am planing on getting a friends M5 soon to compare side by side some on road tests, or some data tests G-Tec or put his car on the same Dyno???
This after market tuning business (as a few members are aware) is a very interesting and very enlightening experience.. most times. I must say I've learnt plenty from all of this, and it's not all negative but it's got my attention.
I must say l love driving the car in it's converted state even if it hasn't got 500+hp from the get go, and I'm still glad l went through it all but, l would have really liked less stress through the project. Nowack need to make their customers feel more important when undertaking such a big personal/financial commitment with them, especially when your thousands of miles away and trusting them 100% with your engine or car.
Here are some of the dyno runs in DIN format if you want a look. Hit enter and they should be there....look at pics 27 to 36.
http://www.imagestation.com/album/?id=4291829125.
APPLES
2000 M5 LeMans blue
Headers/cats/exhaust/KW suspension/sway bars/UUC shifter/UUC clutch/BBS LM 19's.
2003 M5...actually MIB's (master yoda)
2004 Lamborghini Gallardo Pearl Yellow. HRE 840r 19's front 20's rear
2006 Ford GT Heritage blue
www.m5ute.com
Apples is offline
Old 20th May 2002, 18:55   #2
Gustav
Administrator
Gustav's Avatar
Yes, thisis certainly not customer focused!
Nowack don't fulfill their promises as I see it.
Gustav is offline
Old 20th May 2002, 19:08   #3
AJ
they are feeding you bs imo. all they did is lower the back pressure (headers/exhaust), clean the heads (not major porting, just a cleanup that you can do with a dremmel if you are so inclined), provide more aggresive cam grind and advance the timing. guess what the outcome will be? the hp will get pushed higher in the rpm range and the tq will suffer. ram air can contribute max 17-20hp at speeds and that is somewhat optmistic figure- expect more like 15hp at top speed- so that is not the culprit either.
however, what bothers me is that usually when you do something like that the hp rases 2:1 vs. torque. in contrast, the numbers you are quoting here are more like 10:1 - but in your case you gained hp and you lost tq- if done right this should _never_ happen unleast you pushed the hp really high up in the rpms which is not the case...
from what you explaned your engine sounds like a race-prepped one- behaves well at wot, but is not very civilized at anything less than close to redline. said that- my guess is that nowack has some serious problems with the a/f mix at lower rpms and part throttle scenarios... my guess would be that most of your problems are computer tunning related. get you car to a wide-band o2 sensor equipped dyno, do print outs and send them to nowack. see what they say.
i hope nowack will come forward and will clear the issue- it might be something very simple and easily fixed.
alex
02 gts
few other cars
AJ is offline
Old 20th May 2002, 19:19   #4
2001's X5/Z8
2001's X5/Z8's Avatar
Garage: BLACK 2001 X5 4.4
Send a message via AIM to 2001's X5/Z8
Apples,
Long story very short.....Unless they (nowack) plan on attaching that very $$$ air blowing system to your car, you should demand your money back.....It's quite clear that they have attempted to decieve you, and most likely many others. By claiming their abilty to produce X amount of Hp, would not be attempted deciept or fraud had they advertised that the $$$ air blowing system was needed to produce those types of numbers.......They just mistakenly left out??
Their adverstisment should read.....
N500 500 hp at 7,000 rpm (while blowing 160mph of air into the air boxes) and 385 under normal conditions.....
So maybe BMW should consider advertising the BMW M5 as a car that produces 450 HP (with 160 MPH of air) and 394 under normal conditions.....
My point is, what good is it knowing your car an produce X amount of HP under conditions you car will never see??? The only thing you care about is what it does on the road, not what i can do when there is 160 mph of air coming into it, or when it's a full moon it will do 0-60 in 3 seconds going backwards....
Well that was hardly a long story short as I said, but I had a few more things to say....I wish you would let me get in touch with Nowack for you, I would give them a piece of my mind......
sorry for rambling
2001 Z8 BLACK/RED K&N FILTERS POWERCHIP ECU UPGRADE (Thanks Apples)
365RWHP
350RWTQ
Sold, please take care of her
2001 X5 4.4 SPORT BLACK/BLACK K&N FILTER.
M3 Come.. M3 Go
2001's X5/Z8 is offline
Old 20th May 2002, 19:21   #5
MEnthusiast
MEnthusiast's Avatar
Garage: 03 M5
Apples,
thank you for taking the time to share this with us. It is very infomrative. This practice Nowack seems to engage in re: HP claims reminds me of amplifier power output claims made by several popular consumer electronics manufactuers. Youve gotta look at the tiny fine print to see what the testing conditions are.....
All the best,
MEnthusiast is offline
Old 20th May 2002, 19:27   #6
Adam
Adam's Avatar
Garage: R32
Send a message via ICQ to Adam
Apples if i remember correctly..when gustav test drove the nowacked m5 a few years back..they did a comparision of Stock m5 vs nowack..the stock car pulled at lower revs..just like you said..gustav do you remember that?
all the best
adam
1995 Alpina B8 4.6 #10-(engine blew up. sold)
2001 BMW ///M5(sold)
2003 RUF R turbo
1990 RUF CTR
2006 VW Golf R32 DSG
2005 e60 M5 (sold)
2007 997 GT3 RS Carrara White
2008 Renault Clio 197
"You know it is kinda ironic, these old people are being kept alive by the organs of the young people they ran over" - Chief Clancy Wiggum
Adam is offline
Old 20th May 2002, 19:34   #7
Johnny D
Johnny D's Avatar
Garage: 02 M5 Sterling Grey/Black
Thanks for the thoughtful account. This confirms my theory that BMW didn't leave a lot of extra horsepower on the table so to speak. I would be surprised if any of these tuners with their limited vs BMW budgets would have any breakthroughs. Either it will cause premature wear or failure, cost too much vs the gain, or affect driveability to some extent. That said, I'm sure to draw some flames.
"Have a Great M5 Day, You deserve it "!!
Johnny D
M5: Divine Miss "M" (Mistress)
'02 Sterling Grey/black/Luxury/Burl Walnut, M Audio & PDC NO Mods!
04 3.0 Z4 Black
'77 Mustang (Horse NOT the car)
"No Eating, No Drinking & No Advice,
Just get in, shut up and hold on tight"
Johnny D is offline
Old 20th May 2002, 19:39   #8
Bart Carter
Bart Carter's Avatar
Garage: 2002 M5 Bluewater/Caramel
My 2 cents: It sounds like fraud. If this happened to me, I would be posting on every site in the Universe on how I was scammed.
-Bart
2002 Bluewater/caramel
Any other car is a compromise
Bart Carter is offline
Old 20th May 2002, 19:41   #9
2001's X5/Z8
Bingo!!!!
365RWHP
350RWTQ
M3 Come.. M3 Go
Old 20th May 2002, 20:15   #10
greg
greg's Avatar
Garage: 2000 Anthracite
Apples - great discussion.
i think you're still too soft on them - you are trying to find a way to excuse them for their claims. I think that is laudable, but at some point you have to call a spade a spade. here athe key points to me:
  • NOBODY quotes HP and torque figures - which are stated for comparison purposes between competitive products - as only being available at high speed.
  • As I showed you with the Carroll Smith math, and you discovered with your blower experiment, the ram air effect is simply not that great. If you look at the specs on the blowers you used I'm wiling to bet they move air at more than 150mph.
  • No other tuner, given the same kind approach, has claimed anywhere near as much power as Nowack. do we think everyone else is stupid and only Nowack is smart?
  • Unfortunately, Nowack wouldn't be unusual among after-market tuners for making ridiculous claims. Nevertheless, it is false advertising - which is illegal in the United States.
If I were you I would tell Nowack they have one last chance - either deliver a car that meets their original claims, or refund you a portion of your expense in proportion to the amount of HP you didn't get compared to their claim.
And I would talk to a lawyer, maybe before doing the above, but certainly after if they don't agree. I know you're happy with the car, but I don't think you should have to pay for what you didn't get.
greg is offline
Page generated in 0.21052 seconds with 10 queries
