Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E63 BMW M6 Forum and BMW M6 Convertible | m6board.com > M6 E63 Group Buy and Sponsor Discussion and Offerings
M6 E63 Group Buy and Sponsor Discussion and Offerings Only Sponsors are allowed to post there offerings or one-time member offerings (That is one single and first group buy for a non-sponsor company's product).
Old 20th October 2009, 21:26   #1
umnitza
Company representative for Umnitza
umnitza's Avatar
Garage: ///M3, 740i
Sales Feedback: (14)
Send a message via AIM to umnitza Send a message via Yahoo to umnitza
••ü•• Genesis Angel Eyes LCI Models
http://www.umnitza.com/umnitza-xtec-genesi...e60-p-5679.html
Umnitza introduces the Genesis Angel Eyes for E92 and E60 LCI ICE (Integrated Color Enhancement)
A new product that transforms the factory luminescent ring technology to a more technologically modern look. This product will give you a whiter, brighter, halo output. The BRIGHTEST output, OEM PLUG AND PLAY CONNECTOR UPGRADED ANGEL EYES AVAILABLE. COMPLETELY PLUG AND PLAY with NO ERRORS.
CLASS LEADING FEATURES: (not available on any other competing product)
* Patent-pending Narrow-Tuned Beam System
* Patent-pending Spring-Loaded Fixture Assembly
* Patent-pending Spring Balancing Rod System
* All aluminum body
* Four High output LEDs - 2X More than the nearest competitors
* Highest Output LED - 7W Total
* No Error, No Flash Required
* Voltage Stabilizing Device
* 4-Direction Draw Bar Device
Application (Please consult your owner's manual for your application fitment type):
Applications: All H8 BMW Angel Eyes
E82 All,
E90 09+ LCI
E90 M3 All
E92 All
E93 All
E60 08+
E60 M5 08+
E63 08+
E63 M6 08+
E64 08+
E64 M6 08+
E83 X3 08+
E70 X5 07+
E71 X6 08+
Product Description (may describe some optional equipment):
With the narrow tuned beam angle, this ICE enhancement is capable of guiding the light source directly into the aperture of the original lighting fixture. This direct beam output is stabilized by a spring loaded seating and rod mechanism to maximize throughput using the best in class output 7W LED.
The all aluminum body unit provides exceptional heat dissipation, increased LED lifespan, and most importantly - LESS DECAY. Some LED products look good to start, but they are overdriven by their power sources and eventually the LED loses it's "luster". Not here.
The four high output LEDs are twice the amount of the leading competition, but this does not cause any errors on the dash. Further design was carefully scrutinized by engineers to prevent any radio interference despite the increased number of LEDs. Therefore, you just plug and go, no reflashing the computer is required and the ECU just keeps on working and doesn't void your factory warranty.
umnitza is offline
Old 20th October 2009, 22:56   #2
nlpamg
nlpamg's Avatar
Garage: '08 M5 AW/Silverstone
looks pretty good. is it easy to take out? that "swivel" design makes it look somewhat permanent.
nlpamg is offline
Old 20th October 2009, 23:46   #3
umnitza
umnitza's Avatar
Garage: ///M3, 740i
It's easy to put in and easy to take out. The LEDs are spring loaded, so they bend both in and up.
umnitza is offline
Old 22nd October 2009, 06:26   #4
AlpineMsix
AlpineMsix's Avatar
Garage: Alpine 08 M6 manual
so are these for sure the brightest angel eye bulbs/kit u have up to date? MUCH brighter then if u were to use the gp thunders??
for sure no error codes as well
i have an 08 m6.
AlpineMsix is offline
Old 22nd October 2009, 19:45   #5
umnitza
umnitza's Avatar
Garage: ///M3, 740i
i have an 08 m6.
yes, positive
umnitza is offline
••ü•• Genesis Angel Eyes LCI Models umnitza M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 21 31st October 2009 20:34
Angel eyes to replace DRL's 06-07 models macmtr E60 M5 and E61 M5 Touring Discussion 7 12th September 2008 01:11
*AiB* NEW COLOR Angel Eyes: AMBER Angel iBright V2.0 AngeliBright.com M5 E60 Group Buy Forum and Sponsor Discussion and Offerings 0 8th June 2007 20:38
Did you upgrade your amber corner angel eyes for clear corner angel eyes? LOOK HERE! CM5GO E39 M5 and E52 Z8 Discussion 5 17th October 2006 22:11
Do all 2001 5 Series models come with angel eyes? M5Laser E39 M5 and E52 Z8 Discussion 2 4th November 2001 11:00
Page generated in 0.11610 seconds with 11 queries
