Do you have them for the license plate as well? Is anything else needed to replace the lights, or do you just pull the old bulbs and install the new? Any issues with codes or errors? Just wondering because this is 100 dollars less than another for sale in this same section.
You pull out your old bulbs and put in our new bulbs.
V4 - $28.99
and the Ambience is $69.99
So the shipping is calculated on the site at the time of check out
So I got the LEDs in today and I went to install them and I ran into some issues. Firstly, the longer style bulbs were too short for the loctions they were being installed. I made them work by pushing the connections together closer. Another issue is you gave me 2 less bulbs for the dome light fixtures, and instead gave me two longer style bulbs. That isn't the only issue. The issue is I need 6 bulbs, but, all of your bulbs don't work. The reason is as follows: when you pull the bulb holder out of the dome light housing(there are 3) you insert your bulb, and then put the entire piece back in the hole, the problem is, your bulbs width is too big for the actual hole, making it so you can't lock and turn the bulb holder in place.
So what I need is 6 bulbs that will correctly fit in the area in which they belong in the dome light housing. Can you get me this and quickly since this is basically where the majority of the light is from and now the car looks weird with mostly LEDs except the most important part?
Well regardless I don't have 6 dome light bulbs, only 4 remaining bulbs that can go in the dome light fixture. I will send pictures to let you see why they don't work when i'm near the car.
That's how i did contact you. then I replied to your response asking when they would be sent and no response.
125.8K members
