Transform the rear of your E60/1 5 Series.
BMW E60/1 5 Series LCI OEM Tail-lights custom retrofit kit:
Go from the older pre-LCI light to the new LCI light in 15 mins
This upgrade is the best thing you can do to make the back of your car stand out.
Offered here is a custom made (non BMW) harness for the lights that will allow you to plug the OEM BMW E60 LCI (post Mar 2007) tail-lights into a BMW pre-LCI (Mar 2003 - Mar 2007) car.
Not only will these cables allow you to connect the new lights on the older cars but will give you the true LCI look on your pre-LCI car as well. So while driving only the LED rods/tubes will be lit but the moment you press the Brake the filament bulbs behind the tubes will lit up. The Turn LEDs work as before and blink at the same rate along with the other Turn indicators in the car.
This version is professionally made in metal enclosures and is completely solid state with no moving parts or relays. This version will stop the LED lights from "Strobing" when you start up the car up for about the first 4-5 seconds.
However these cables are made using OEM BMW plugs and connectors to obtain perfect fitment. You will not require any dealer installation or programming. They are completely plug and play, do don't need to cut any wires and the process is completely reversible. You should be able to fit these lights and cables yourself in about 15 mins. These lights will also not give you any iDrive errors and all your current features of the taillights will be retained inc Rear Fog lights, Brake Force Display, Parking Lights etc.
The cables are installed under the lights themselves using custom made mounting brackets (supplied).
We can offer the following:
loom on its own for £ 270.00 (E60 + E61)
loom and genuine bmw E60 LCI lights £ 435.00
loom and genuine bmw E61 LCI lights £ 555.00
Price's inc UK VAT so cheaper for people outside of the EU.
