aFe POWER - M5/M6 Cold Air Super Stock Intake System
Open up that huge V-10 engine with this newly released aFe cold air super stock intake system for the BMW M5/M6. Your M5/M6 stock intake is very restrictive. That V-10 needs a lot of air in order to feed that monster of an engine. This aFe intake kit increases air intake flow by 45%, allowing the engine to suck in as much air as need, easier. This means huge horsepower gains throughout the entire rpm range. Do not leave your M5/M6 gasping for air any longer, get an aFe cold air super stock intake system today.
The Super Stock air intake system from aFe includes a Pro 5R performance air filter, Dynamic Air Scoop (D.A.S.) and restore kit that increases air flow 45% over the factory air intake system. The Pro 5R air filter uses a progressive 5-layer cotton gauze media for maximum flow and performance. The Dynamic Air Scoops are constructed of lightweight aluminum and help guide the air through the kidney bean grille into the air intake for maximum flow and velocity. You will feel the improved throttle response and power immediately.
Benefits
AFE Pro Dry
50% air flow over stock (This would be like comparing a panel filter to OEM panel)
99.2% filtration
AFE Pro 5R (oiled)
75% air flow over stock (This would be like comparing a panel filter to OEM panel)
98.6% filtration
About AFE Filters
AFE filters are constructed from 100% poly-urethane which makes them very durable, and resistant to high temperatures and chemicals. The construction of the pleats in the filter is deeper than that of any other filter, this provides for an increased flow and prevents a greater amount of dust from reaching your engine.
E-Mail Kevin@ModBargains.com or call me directly at 714-582-3330 ext 8009
Kevin
Benefits
- Increase in HP and TQ
- Pro 5R air filter design
- Includes intake scoops
- 45% more air flow
- Easy Installation
- 06-10 E60 M5
- 06-10 E63 M6
- 06-10 E64 M6
AFE Pro Dry
99.2% filtration
AFE Pro 5R (oiled)
98.6% filtration
About AFE Filters
- Durable construction
- Deep pleats for increased filtration
- Washable/re-useable
Kevin
