13th July 2010, 21:22
#1
E46 330i ZSP
Jlevi SW | RDSport Sway Bars for the E60 M5
RDSport's lightweight hollow sway bars weigh in at 8.5lbs each, and are adjustable to be between 16 and 33% stiffer than the factory sway bars. These sway bars not only increase the overall spring rate to reduce body roll at any setting, but are also adjustable for the rate of spring rate increase, and will yield much more aggressive handling response. By enabling the driver to change the rate of increase of the swaybar stiffness, RDSport swaybars will help tune out understeer on initial turn in.
Fits the E60 M5 & E63/E64 M6.
RDSport Sway Bars Feature:
- * 30.2mm Front Bar Thickness
- * 22.2mm Rear Bar Thickness
- * Increased Stiffness and Handling
- * Replacement Urethane Bushings
- * Lightweight Hollow Construction
- * RD Green Powder Coat Finish
A must have for any track enthusiast.
