Drawing on over 150 years of spring design and manufacturing expertise, B&G S2 Sport Springs are engineered to improve handling while maintaining safety and ride quality.
By redesigning the O.E. Spring and the lowering the center of gravity from 1-2.5" (depending on vehicle and application) B&G technicians dramatically improve your vehicles performance and appearance. Incorporating a progressive rate design allows B&G Springs to offer higher rates for improved road hold, while maintaining a comfortable ride
B&G S2 Springs Feature:
Cold wound from high tensile chromium silicone wire
I'm in the market for a good set of lowering springs that will give my 2007 M5 the right stance w/o comprimising the ride or shall we say w/ as little sacrifice as possible. My local Euro Mods dealer recommended AC Schnitzer springs. What can you tell me about your springs? Do you have any before or after pics & do you recommend spacers? I have Vertini 19" wheels on my car.
These springs offer a progressive spring rate which translates to better handling while maintaining a relatively good level of comfort. I'm not that familiar with ACS lowering springs but I can tell you that I am running these springs on my E39 M5 with Koni Sport shocks and the comfort levels are very close to OEM, a bit firmer but very tolerable even in the worst road conditions.
Unfortunately I do not have any before and after pics of these springs on the E60 M5 but the advertised drop is accurate.
In regards to spacers, it all depends on how flush you want your wheels to be with the fender. You will probably want to drop the car first with a set of springs (new aftermarket shocks are highly recommended in order to maintain optimal comfort and handling) before considering spacers as you will want to see how much room you are working with first.
Thnaks for the prompt response, I'm going to do a little more research locally to see what the BMW dealer recommends as well as my local Euro mods dealer GMP. I'm sure they've done a few installs.
New aftermarket shocks is recommended but not required. The stock M5 shocks are more than enough to handle the increased stiffness of these lowering springs.
id like to see some pictures of these springs installed and compared to other companies as far as the ride height and it not having the raked look
125.8K members
