cal@jlevisw.com | 1.888.JLEVISW | JleviSW | Your #1 Source for High-End BMW Enhancements
StopTech stainless steel brake lines improve pedal feel and reduce the amount of time between applied pedal pressure and actual deceleration by preventing expansion, which stock rubber flex lines allow. This provides a quicker pedal response, and allows the driver to maintain consistent brake pressure and precision brake modulation.
StopTech brake lines feature:
- Teflon¨ inner lining
- Outer layer of stainless steel woven braid
- Teflon tube is very resistant to expansion under pressure
- Will not degrade from exposure to brake fluid
- Stainless steel braid provides support for the Teflon
- Extremely durable weave withstands incidental impact and abrasion
- Clear Abrasion Resistant Cover for maximum protection against chaffing
- DOT (United States Department of Transportation) compliant
- 100% tested to a pressure of 4500 psi
