cal@jlevisw.com | 1.888.JLEVISW | JleviSW | Your #1 Source for High-End BMW Enhancements
We are proud to announce that we now carry SuperSprint's Full Line of Exhaust products for your beast! :biggrinbounce:
We got everything you need for a full SS Performance Exhaust System.
Supersprint Headers for the E60 M5, E63 M6, and E64 M6 feature an innovative long tube header design and top quality materials to upgrade your M6 or M5 to a monster!
Supersprint's Headers for the E60 M5, E63 M6, and E64 M6 Feature:
- Innovative long tube header design with primary tubes fitted independently of the 5 into one floating merge collector
- Excellent thermal expansion to avoid cracking at the merge collector
- Makes 52 horsepower and 37 ft lbs of torque
- Leak proof joint, guaranteed
- CNC laser cut port matched flanges
- Mandrel bent primary pipes
- Minimum weld joints for structural integrity
- 100% stainless steel
- No Check Engine Lights
- Works with OEM secondary cats, or Supersprint Race Cats
This Supersprint X Pipe for the E60 M5 is mandrel bent for maximum performance.
All Supersprint X Pipes Feature:
- Mandrel bent
- Increases volume of exhaust
- Replaces stock resonator
- Reduced Backpressure
- Polished 304 Stainless Steel
This Supersprint Metallic Catalyst for the E60 M5 is mandrel bent for maximum performance, while maintaining a catalyst to control volume and emissions.
These Metallic Race Cats Feature:
- Mandrel bent
- More robust than OE cats which will melt down if you've upgraded the power of your S85 V10
- High heat resistant metallic core
- Reduced cell count from 400 C.P.S.I. to only 200; the most free-flowing system on the market
This Supersprint Resonated X Pipe for the E60 M5 is mandrel bent for maximum performance, while maintaining a center resonator to control volume.
- Mandrel bent
Adding a Supersprint Sport Muffler to your E60 M5 will yield an increase in power while providing a menacing growl and improved aesthetic.
All Supersprint Sport Exhaust Systems Feature:
- Mandrel bent pipes for maximum flow
- Increases volume of exhaust with a distinct and pleasant growl
- Replaces stock muffler
- Saves weight over bulky OEM systems
