cal@jlevisw.com | 1.888.JLEVISW | JleviSW | Your #1 Source for High-End BMW Enhancements
Read & Reset your check engine, airbag and fault codes without costly BMW dealer visits!
Compatible with all 2001-2010 BMWs. Single VIN version is availble only with a JB+ or JB3 product.
A true "game changing" product, the Bavarian Technic BT Cable does everything a GT1/OPS system can and much more for a fraction of the price, including reading/deleting extended codes, check engine light reset, tuner detection codes, and airbag light reset/codes. It also performs high speed data logging of over 600 parameters including engine knock, adaptation values, O2 sensors, boost targets, etc.
Bavarian Technic cable works on Engine, Airbag, ABS, Transmission, OEM BMW Alarm, Central electronics, Heating & A/C,And much more...
Plugs directly into your factory OBDII diagnostic port under your dash on the drivers side.
Our hardware solution consists of an adapter cable which has one end that plugs into the USB port of a laptop or desktop computer and another end that plugs into the OBDII diagnostic port of your car. Since our hardware supports USB it is compatible with most computers.
What can it do?
- The tool accesses the electronic control units in your BMW to:
- Read and clear diagnostic fault codes
- Display shadow faults and soft faults
- Display and record real-time actual values
- Activate components of the car for troubleshooting
- Reset service reminders
- Reset condition-based service indicators
- Send special commands to control units
- Show ECU information
- Access the latest BMW DCAN systems for 2007+ models
