M5 E60 Group Buy Forum and Sponsor Discussion and OfferingsOnly Sponsors are allowed to post there offerings or one-time member offerings (That is one single and first group buy for a non-sponsor company's product). Members are allowed to post here as well.
Umnitza introduces the Genesis Angel Eyes for E92 and E60 LCI ICE (Integrated Color Enhancement)
A new product that transforms the factory luminescent ring technology to a more technologically modern look. This product will give you a whiter, brighter, halo output. The BRIGHTEST output, OEM PLUG AND PLAY CONNECTOR UPGRADED ANGEL EYES AVAILABLE. COMPLETELY PLUG AND PLAY with NO ERRORS.
CLASS LEADING FEATURES: (not available on any other competing product)
* Patent-pending Narrow-Tuned Beam System
* Patent-pending Spring-Loaded Fixture Assembly
* Patent-pending Spring Balancing Rod System
* All aluminum body
* Four High output LEDs - 2X More than the nearest competitors
* Highest Output LED - 7W Total
* No Error, No Flash Required
* Voltage Stabilizing Device
* 4-Direction Draw Bar Device
Application (Please consult your owner's manual for your application fitment type):
Applications: All H8 BMW Angel Eyes
E82 All,
E90 09+ LCI
E90 M3 All
E92 All
E93 All
E60 08+
E60 M5 08+
E63 08+
E63 M6 08+
E64 08+
E64 M6 08+
E83 X3 08+
E70 X5 07+
E71 X6 08+
Product Description (may describe some optional equipment):
With the narrow tuned beam angle, this ICE enhancement is capable of guiding the light source directly into the aperture of the original lighting fixture. This direct beam output is stabilized by a spring loaded seating and rod mechanism to maximize throughput using the best in class output 7W LED.
The all aluminum body unit provides exceptional heat dissipation, increased LED lifespan, and most importantly - LESS DECAY. Some LED products look good to start, but they are overdriven by their power sources and eventually the LED loses it's "luster". Not here.
The four high output LEDs are twice the amount of the leading competition, but this does not cause any errors on the dash. Further design was carefully scrutinized by engineers to prevent any radio interference despite the increased number of LEDs. Therefore, you just plug and go, no reflashing the computer is required and the ECU just keeps on working and doesn't void your factory warranty.
Why is it 30-50minutes to install the product if it is plug&play ?
Well, most people take their time doing the install. If we had said it takes only 10 minutes - and someone takes 1 hour trying to figure out how to open their high beam cover (when they should be opening their low beam cover...).
Furthermore, each car is different - for example, the 6 series takes longer because in some cases, you may have to remove the front wheel and access the stuff through the wheel well, while in the X3, it may take 1 minute because it's right in front of you. MOST people have to remove the E60 headlights to get the bulb swapped (we don't all have small hands) but some people have no problem doing it while it's on the car.
Hope that explains it better.
Just to clarify: The install process is the same as replacing the H8 bulb, correct?
I didn't mean to say I am a faster installer or anything like that. I just thought there was more to it.
__________________ 2010 BMW ///M5 INDIVIDUAL {Frozen Grey/Platinum/Platinum Alcantara/Piano Black Trim} - IN PRODUCTION!!!
~Mods: HRE 20" P41 [Black&MachinedFace], Eibach Pro-Kit Springs 2008 BMW ///M5 N. AMERICA {Black Sapphire/SilverStone II/Black Alcantara/Aluminum Trim} - LEASE UP 01/2010
~Mods: Black Grills, Black Gills, Black Roundels, White AngelEyes, Charcoal Filters Deleted, RPI Scoops, BMC Filters, DINAN Software, DINAN Exhaust, DINAN 13% Pulley
Other Vehicles: 09 MERC S65 AMG [BLACK], 09 MERC S65 AMG [WHITE], 09 MERC SL63 AMG, 07 BMW ALPINA B7
Previous Vehicles: 08 MERC S63 AMG, 06 RANGEROVER S/C
Thank you. Let me know if there are any issues on our site.
The checkout process was ok however for AMEX the CVCC field was limited to 3 characters when the AMEX cvcc is 4 characters (unlike visa which is 3 characters). So I put the full 4 digit cvcc in the notes field.
Other than that, everything worked fine.
Just installed them on my '08 E60 M5. They are considerably brighter than OEM (installed during daytime).
However, I'm getting an error on both sides. Here is the screenshot:
