Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E39 M5 and E52 Z8 Discussion > M5 E39 Group Buy Forum and Sponsor Discussion and Offerings
Old 20th November 2008, 04:04   #61
BKM5
BKM5's Avatar
Garage: 2002 M5 Sterling Gray
Sales Feedback: (4)
Has anyone seen this gulf version 11427511171 in person referenced above and listed for the 540? I'm wondering if it is and additional inlet and outlet. When I look at the pic's here RealOEM.COM * BMW E39 540i LUBRICAT.SYST.-OIL FILTER, OIL PIPES for the gulf version 540 and then here RealOEM.COM * BMW E39 M5 LUBRICAT.SYST.-OIL FILTER, OIL PIPES for the US E39 M5 I see no difference in the inlet and outlet setup. Each has one inlet and two outlets shown. Maybe the first link for the 540 is not the gulf version shown as the standard has the same p/n as the Us std M5 housing(probably not), but I wanted to confirm an additional set of inlet and outlet connections on this gulf version as I'm in the process of planning an aftermaket oil cooler of some type like the B&M supercooler or something.
Hey Gsfent can you pm me your installer info and final price if you don't mind and give me an update if your happy with your setup?
BK
AA Twin Rotrex Supercharged, KW V3's, Tubi Regular, V-1, 9.5 OE's all around and rear Eibach sway bar.
BKM5 is offline
Old 23rd November 2008, 15:49   #62
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
BK
Install was a one off, so if you want him to do it, I have to get a price.
We haven't totalled it up yet, I still don't have a bill for labor!! He did spend some time figuring out where everything goes, and I know he removed the front bumper to do the install. If and when the SC kit from ESS comes out, we may have to move it around a little, it now sits dead center and low in front of the rad for plenty of fresh air.
From memory, parts were around $400-$500, included the oil cooler, new oil filter housing with remote for lines, lines themselves, and some misc. stuff.
I haven't tracked the car, but during the hot months, it seems to work fine. I note the 90 C degree T stat (built into the oil filter housing IIRC) seems to work, although there is a bit of delay from the reading to the opening. Seems to open closer to 98 or 99, then temp drops about 10 degrees almost immediately. Installer surmises simply slow reaction of the temp sensor to actual temps, but in all other respects, I have no issues.
Holds about 1.5 extra quarts, not a bad thing, although makes oil changes a little less complete since the cooler doesn't drain. But I am on a 7500 mile interval anyway.
PM for more details, or if you want to see the car.
gsfent is offline
Old 1st January 2009, 02:55   #63
LFC09
LFC09's Avatar
Garage: CarbonBlack E39 M5
any further updates on this Jerry?
I am interested in an oil cooler as I will probably be tracking my car more. Gets quite hot here too.
side note, I will have to investigate the tstat too, might only open partially as oil temp mostly 94-99C, even at highway speeds.
Scott
2002 M5 Carbon Black
Black/Grey leather
Brushed Aluminium trim
AiB 3.0 angel eyes
AiB xenon match fogs
BMW 545 shifter
Dinan rear sway bar
TCD rear sway bar brackets
X5 4.8 thrust arm bushings
Bimmernav Bluetooth upgrade
phone cradle V3xx modified
Solaris invisi-bulbs
MkIV Nav V31 custom splash
ex 1959 FC Holden sedan
LFC09 is offline
Old 2nd January 2009, 05:45   #64
gsfent
gsfent's Avatar
Scott
Nothing further to report.
In normal driving, it is transparent, can't tell it is there. When summer returns, it should help a little, and if I track the car, I should have a huge safety margin.
gsfent is offline
Old 1st September 2009, 00:47   #65
XCUSM5
XCUSM5's Avatar
Garage: Porsche 996TT & E39 M5
thread revival... anyone have a basic put-together kit? i am adding some mods including pulleys so I have a bunch of things off and a oil cooler would be nice.
XCUSM5 is offline
Old 2nd September 2009, 00:05   #66
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (3)
Send a message via Yahoo to herrubermensch
I ordered the "Gulf" version of the oil filter housing that has a built in thermostat and outs for an oil cooler. About $350 from your local Stealership. I intend to swap locations of the oil filter housing with the power steering reservoir, then run XRP HS-79 hosing from the new housing to a Mocal 16 or 19 row oil cooler mounted behind the kidneys. This is pretty much what T-Trim 540 and Gsfent have done. Total cost with housing, oil cooler and hosing and fittings is about $700, and it looks pretty easy to install. I'm doing this at the same time as my ESS SCer install.
BTW, the part number for the Gulf version of the oil filter housing ends in 171, not 169.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Dinan 3.45 Differential, GC Coilovers (550 Front/325 Rear), Dinan Front and Rear Swaybars, Dinan Monoballs, Dinan Wheels (18 x 9 Front/18 x 9.5 Rear), Bridgestone RE050 RFTs (275 Front/285 Rear), UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, Zionsville Super Duty Cooling System, OKD Plasma Ignition Coils and Plug Boots, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Custom Stereo Using Stock HU, PLX Digital Gauge, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, Schroth 4-Pt Street Harnesses, and Various Other Bits and Pieces
Coming Soon!
Stoptech "Trophy" Brakes, TC Designs Roll Bar, TC Designs Rear Sway Bar Brackets, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, Rogue Stage 3 280mm Clutch with JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement and Dinan Foglight Deletion Kit.
When the Motor Blows
Balanced and Blueprinted S62
herrubermensch is offline
Old 2nd September 2009, 07:48   #67
E55AMG2
E55AMG2's Avatar
Peter,
why not run the BMW lines and cooler as well?
E55AMG2 is offline
Old 4th September 2009, 06:57   #68
herrubermensch
Sales Feedback: (3)
Originally Posted by E55AMG2 View Post
Peter,
Hey Mike. Not sure exactly what you mean. There is no specific BMW oil cooler for the e39 M5 other than the under-plenum heat exchanger that, with an external oil cooler, can and should be removed ala Dinan. Thus, one has to use something else, and Mocal is as good as any other. In terms of the hosing, again, BMW makes oil lines for the standard oil filter housing, but as far as I know, there are no specific oil lines for an oil cooler for the E39 M5. XRP HS-79 is pretty much the best lightweight hosing out there and used on all the D/A Sc'd beasts.
--Peter
The Beast
Coming Soon!
Old 4th September 2009, 07:14   #69
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
Are you planning on removing the factory cooler then?
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Old 4th September 2009, 10:01   #70
E55AMG2
E55AMG2's Avatar
--Peter
The "gulf" oil filter housing is a 540i part. Incidentally both the M5 and 540i the same shrouding/brackets as the M5 to hold the a/c condenser and pusher fan. If you notice to the side of your A/C condenser there is a big open space, this is where the oil (and trans, which fits in the lower section of the opening) cooler goes on the gulf cars. Im sure you can use a much bigger rectangular (vs square on the factory part) oil cooler since you have no need for a trans cooler. I've been looking into doing this myself, as I track my M5 quite a bit and regularly see oil temps between 230 and 260F when running flat out.
Check RealOEM for all the part #s, but I assure you the parts do exist. From memory; there are 2 oil lines, a bracket, a bunch of hardware items/clips, and the cooler along with the filter housing + tstat. I'll search and post the P/N's later on.
E55AMG2 is offline
The Following User Says Thank You to E55AMG2 For This Useful Post:
herrubermensch (10th September 2009)
Best source for 10-60 synthetic?? CBarton E39 M5 and E52 Z8 Discussion 18 25th February 2006 03:30
Dipstick question unfoundhorsepower E60 M5 and E61 M5 Touring Discussion 7 11th February 2006 18:37
Help - Oil From Somewhere x703jko E39 M5 and E52 Z8 Discussion 9 27th December 2004 15:03
How Much $$ Do You Pay for an Oil Change?? cohenfive E39 M5 and E52 Z8 Discussion 31 4th September 2004 03:28
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.15886 seconds with 12 queries
