Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E39 M5 and E52 Z8 Discussion > M5 E39 Group Buy Forum and Sponsor Discussion and Offerings
Old 8th September 2008, 06:19   #51
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
Originally Posted by gsfent View Post
We don't have a "stock oil cooler", although the oil is routed through the plenum. When the coolant heats up, it tends to heat up the oil, which is counterproductive. We didn't touch the stock setup on the theory the extra capacity of the oil cooler will keep the oil cool enough and actually help a little with the coolant temps.
Incorrect. There is an oil cooler located under the plenum, the oil is cooled (and warmed) by the engine coolant. It has a control valve, which may be a thermostat of sorts.
RealOEM.COM * BMW E39 M5 LUBRICATION SYSTEM, ENGINE OIL COOLING
The big question is, where is the oil filter and the factory oil cooler in the oil circulation loop?
I think it would be best to get rid of the factory oil cooler completely, this might give slightly cooler coolant temps since it's not absorbing heat from the oil, and if the coolant is slightly cooler, it might help keep the oil temps under control too.
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
The Following User Says Thank You to xr4tic For This Useful Post:
gsfent (8th September 2008)
Old 8th September 2008, 08:09   #52
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
it also removes a heat sink from below the plenum.
Jerry, one thing i don't understand is your comment on warmer oil temps, how'd that happen?
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 8th September 2008, 16:18   #53
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Not sure if it is variation in outside temps and humidity or a difference in the addition of the oil cooler. I notice what appears to be a slight increase under cruising mode.
As for explanation, I can only assume that when the new oil cooler t stat is closed, the temp will run slightly hotter, when open, it will help keep the temps in check. I don't know if the extra plumbing (more distance to travel) or the increased capacity (about a quart and a half) has any impact on temps.
gsfent is offline
Old 15th September 2008, 07:45   #54
E55AMG2
E55AMG2's Avatar
the extra capacity will help with absorbing more heat, have you ever looked into a B&M supercooler jerry?
E55AMG2 is offline
Old 17th September 2008, 04:57   #55
mfizzlenyc
mfizzlenyc's Avatar
Garage: 2000 m5 silverstone
I dont know about the custom setup
The thing is to have the correct oil temp for changing outside temps and humidity
2000 Silverstone M5 extended Leather
BBS LMs 19s ,StopTech BBK,Dinan Headers Dinan CF -CAI,Dinan light weight flywheel,Dinan stage 3 suspension, Dinan stage 4 software ,Dinan 3.45 Diff,Dinan Mufflers,SS race cats ,SS x pipe,Rogue SSK , Euro Headlights -ibright v3,MRTM Pedal set, updated steering wheel ,16:9 nav ,Active Auto brake ducts
2009 135 Space gray Black Boston Extended Leather
mods- Bmw Performance Black kidney grills,
1988 10th anniversary Rx7 turbo-mods... 93 rotors 3mm seals streetported lapped and balanced 6 puck non organic clutch Turbo back exhaust blah blah blah
1972 Corvette Stingray 454 4 speed man. Show car condition -FOR SALE
mfizzlenyc is offline
Old 17th September 2008, 05:39   #56
gsfent
gsfent's Avatar
No, what is that?
gsfent is offline
Old 17th September 2008, 05:40   #57
gsfent
gsfent's Avatar
Since the setup has a thermostat, that should not be a problem.
gsfent is offline
Old 19th September 2008, 00:07   #58
mottati
mottati's Avatar
which the stock system does an adequate job of. Problem is if you track the car, on a warmish day, you will overheat with the stock set up, assuming you're really driving. I've never had any issues on the street, but a summer track day, about 4-5 good laps is all it's good for before the oil and coolant temps start getting into dangerous territory.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 28th September 2008, 21:15   #59
gsfent
gsfent's Avatar
Recent question of why oil may run slightly hotter with my setup.
I checked with my installer, who checked with his inside BMW source. No real explanation other than slightly different atmospheric conditions and possibly the extra capacity of oil keeps the heat slightly longer. But they did confirm that the OBC temp sensor is slow to react, so when I see 93-94C, it just a slow reacting temp sensor. So that would tie in with slightly higher heat capacity and slightly longer to shed it.
I did a few runs and when the temp hits 93 -94, it will suddenly plummet to 88. This is the Tstat opening up, probably shortly before I see the slow reacting temp sensor info on board.
Hope that helps.
Otherwise, car is running great, just turned 78k. Just waiting for the SC kit to come out...
gsfent is offline
Old 28th September 2008, 21:47   #60
E55AMG2
E55AMG2's Avatar
No, what is that?
Universal SuperCoolers
E55AMG2 is offline
The Following User Says Thank You to E55AMG2 For This Useful Post:
gsfent (2nd October 2008)
Best source for 10-60 synthetic?? CBarton E39 M5 and E52 Z8 Discussion 18 25th February 2006 03:30
Dipstick question unfoundhorsepower E60 M5 and E61 M5 Touring Discussion 7 11th February 2006 18:37
Help - Oil From Somewhere x703jko E39 M5 and E52 Z8 Discussion 9 27th December 2004 15:03
How Much $$ Do You Pay for an Oil Change?? cohenfive E39 M5 and E52 Z8 Discussion 31 4th September 2004 03:28
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.13699 seconds with 12 queries
