Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E39 M5 and E52 Z8 Discussion > M5 E39 Group Buy Forum and Sponsor Discussion and Offerings
Old 14th December 2006, 01:04   #31
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Originally Posted by mottati
I'm open to suggestions if you have a link to the parts required to do this less expensively. It seems that one issue is taping into the oil filter lines, which are not a standard off the shelf part. Compared the the $4000 dinan oil cooler, i thought 1k seemed pretty reasonable. Other bmw vendors sell kits for 'simpler' cars, like the US E36 M3 for the $500-800 range.
as a refresher, ard posted above, #20, about tapping into the filter based on realoem. It would still be a few hundred dollars for oil cooler, hoses, etc. so a kit for grand doesn't seem all that out of line to me either. Rev, if you can hook us up with a plug and play kit for a lot less, I am listening!!!!
gsfent is offline
Old 14th December 2006, 07:19   #32
Machtig
Machtig's Avatar
Garage: 2001 M5 in Jet Black
I will have to research this, as I too would like an oil cooler, but will not spend a g for it.
2001 Jet Black///M5
Supersprint Headers, Race Cats, X-pipe, and Magnum mufflers, Dinan CAI, High flow MAF housings, Stage 4 Software, Ground Control suspension, Stoptech ST-40 BBK, Umnitza Predator Thinline demon eyes, Zionsville Super Duty Radiotor/Fan system, UUC short shift kit, Dinan brake duct kit, Odyssey lightweight battery, V1 w/ Stealth One, Blinder
1998 Cosmos Black ///M3
OEM LTW wheels, M50 manifold conversion and cold air intake, Stromung cat back exhaust, waiting to be installed: Ground Control coilovers/adjustable camber plates, SPC adjustable rear lower control arms, factory RTABS w/ GC shims, UUC Ultimate FCABs, new OEM front control arms, HMS motorsport reciever hitch, Michelin P/S A/Ss, factory motor mounts, UUC transmission mounts w/ enforcers, Sparco harness bar.
1985 Jeep CJ-7
Too much to list...
RIP
1995 Avus Blue ///M3
1997 TiAg ///M3
1986 Toyota HiLux 4x4
1979 Jeep CJ-7
Machtig is offline
Old 13th April 2008, 19:23   #33
03E39M5
03E39M5's Avatar
Garage: 03 Titanium M5
Any News???
After doing a search and revisiting this thread almost a year and a half later (now April, 2008) still no Oil Cooler.
Any news on this? Anyone done it for less than $1000k. Summer is around the corner and the track is calling!
03E39M5 is offline
Old 18th April 2008, 01:01   #34
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
nothing on my end, getting kind of bored with the e39, so no motivation from me. The only good option that is readily available is from dinan, and instead of putting another $4k into the e39, i'd rather buy a new m3 for track days!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 18th April 2008, 02:03   #35
03E39M5
03E39M5's Avatar
hey mottati: I was kinda toying with the idea of making the e39 more of a 'ring taxi track machine for the occasional private track rental days with the buddies, but that aint gonna happen without an oil cooler. Its been fun in the past running down all sorts of hot 2 seat sports cars with 4 guys in the M5 waving goodbye out the back window!!
If worse comes to worse I can always get a shop I know to put something together, but hate to be the guinea pig!
I guess if you are the only place in the world that makes this, you can ask $4k for it! Its probably $400 or less in parts plus a couple hrs labor.
we will figure somehting out!!
03E39M5 is offline
Old 18th April 2008, 02:06   #36
mottati
mottati's Avatar
if it came up, i'd probably buy one! My e34 has a nice large air to oil cooler under the rad, nice design, takes it longer to warm up, but never gets too hot. This is what we need to add to the e39.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 18th April 2008, 22:00   #37
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
I'm sure there are plenty of places that could take the stock oil filter return hose, cut it in two, put AN fittings on it, which could then lead to an oil cooler.
A thermostat isn't really that expensive, a quick google search says $116.50 for a Mocal thermostat with AN fittings - http://64.202.180.37/files/thermos$....t1=Get+Pricing
I'm not sure what size cooler to get, but a Mocal cooler is $100-$200 for small-medium sizes.
http://64.202.180.37/files/cool$.pdf
Can probably find them cheaper wtih more looking.
Figure another $200 or so for AN lines/fittings, and you've got all the hardware for ~$500
I'm curious if the oil filter is before or after the stock oil cooler. If it's before the stock cooler, then the stock cooler will just warm it back up again.
If there was a way to bypass the stock cooler, then it may help reduce the coolant temps a bit too, since it's not absorbing heat from the oil also.
Looking at the stock oil cooler on Real OEM, I bet you could cut the coolant lines off the cooler, weld a tube to connect them, then reinstall it. Oil would still run through it, but no more engine coolant.
http://www.realoem.com/bmw/showparts...65&hg=11&fg=30
It also shows a "Control Valve" I wonder if it controls the oil flow through the cooler, maybe it can be modified so it bypasses the cooler.
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Old 19th April 2008, 15:06   #38
noxcape
Garage: Hellrot M5 E39
Good day!
I will go with another setup.
I'll get a BMW 550i (E60) oil cooler (it's the big, huge see it here http://www.realoem.com/bmw/showparts...64&hg=17&fg=05) and BMW 540i (E39 Gulf Version) Oil filter with oil cooler connection (see it here http://www.realoem.com/bmw/showparts...91&hg=11&fg=30... and some pipes ...
That Oil filter housing has a thermostat on it ...
My 2003 BMW M3 E46 SMG - Imola Red
My 2003 BMW M5 E39 (BMW Individual - Fueller Hellrot)
Ich liebe mein Europa!
noxcape is offline
Old 22nd April 2008, 02:41   #39
THRILOS5
THRILOS5's Avatar
Garage: 2001 m5 black
Sales Feedback: (3)
very interested in the oil cooler set up, let us know how it works out
e39 M5
Audi S4
300ZX tt 580hp@20psi
Mustang GT 5.0L
Suzuki GSXR750
THRILOS5 is offline
Old 22nd April 2008, 05:27   #40
gsfent
gsfent's Avatar
Originally Posted by noxcape View Post
Good day!
I understand the oil filter housing choice ( I agree), but why the E60 oil cooler? I wouldn't think there is any compatibility between the E39 and the E60. Wouldn't a Mocal or Earl's oil cooler be better able to be chosen to fit? Or have you measured teh E60 cooler and determined it will fit in our cars?
gsfent is offline
Best source for 10-60 synthetic?? CBarton E39 M5 and E52 Z8 Discussion 18 25th February 2006 03:30
Dipstick question unfoundhorsepower E60 M5 and E61 M5 Touring Discussion 7 11th February 2006 18:37
Help - Oil From Somewhere x703jko E39 M5 and E52 Z8 Discussion 9 27th December 2004 15:03
How Much $$ Do You Pay for an Oil Change?? cohenfive E39 M5 and E52 Z8 Discussion 31 4th September 2004 03:28
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.11747 seconds with 12 queries
