Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E39 M5 and E52 Z8 Discussion > M5 E39 Group Buy Forum and Sponsor Discussion and Offerings
Old 23rd August 2006, 01:32   #21
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Now that is a nice find, i searched real oem without luck, but probably ran out of patience before i choose the correct car. Now IF we could get that, and the hoses, i wonder if it could connect to the e46 cooler?
The other issue, dinan IS going to release an E39 oil cooler "kit", which will still be expensive, but not $4k.
The dinan kit is really nicely done, eliminates the under plenum water / oil heat exchanger, which reduces intake air plenum temps, and has a thermostat.
Originally Posted by M5sedan
I found the corresponding oil filter housing WITH oil cooler connections - 11 42 7 511 171. It was used on 840Ci's, E32's and E38 740 M60's and the such - depending on market and version. If you have EPC, look at a 540 ECE version in group 17 - diagram 17_0117 - this will show the cooler, hoses and mounting along with an air channel for the cooler. Just don't ask me where the cooler mounts or where the duct goes..........I am at a loss unless someone with an E39 that has it can shed some light on this - tropical or gulf states more likely........
Hope this helps. By the way, I would be interested in this as well........
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 24th August 2006, 21:50   #22
TiSiBeast
TiSiBeast's Avatar
Garage: 2000 E39 M5 TiSi, 2002 Jeep GC Gray
What will be the primary benefits of the oilcooler?
Current Toys: 2000 M5 with lots of goodies, 1997 993 Targa mostly stock, 2002 Jeep GC all set for offroad, 2004 Acura TL bone stock
TiSiBeast is offline
Old 25th August 2006, 07:00   #23
mottati
mottati's Avatar
Uh, cooler oil... and coolant temps. Essentially, you will be able to track the car on a warm (>75F degrees) day without the concern of overheating. A stock car will overheat after a few laps, especially in warm weather.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 8th October 2006, 03:18   #24
03E39M5
03E39M5's Avatar
Garage: 03 Titanium M5
Guys: Il just talked to Shawdowman and he is still waiting for enough interest in this to make it happen.
If you track your M5...especially anywhere hot like here in SoCal, you NEED an oil cooler BIG TIME!
I MUST HAVE ONE!!!
What's the latest here??
03E39M5 is offline
Old 15th October 2006, 21:41   #25
tfung
tfung's Avatar
I'm quite interested in this if the price is below $1000.
How many units do they need in order to make it happen?
US Spec 2001 E39 M5 - LHD
AC Schnitzer
Dinan
3.45 differential
Others
Euro Spec 1999 E39 M5 - RHD
2007 Mercedes E63
2007 Corvette Z06
2008 Nissan GTR
tfung is offline
Old 20th October 2006, 06:33   #26
mottati
mottati's Avatar
not much hapening. Discovery wanted 10 to make it worthwhile to make a 'kit' for around a grand. Haven't had time to explore the other options yet. Not likely that i'd be too motivated until the (warm) track season comes back.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 21st October 2006, 01:51   #27
03E39M5
03E39M5's Avatar
Well, no offense intended, but I dont think's that this GB is gonna happen.
I have just taken delivery of a brand new Zionsville super duty radiator. Hopefully, this radiator in combination with the factory heat exchanger will do the trick.
.....we will know by the next track event.
03E39M5 is offline
Old 21st October 2006, 02:12   #28
mottati
mottati's Avatar
No offense taken, i don't think it's going to happen either. I also don't think a new radiator will make any difference, but at least that's one less thing for you to worry about failing as the car ages.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 13th December 2006, 13:17   #29
Machtig
Machtig's Avatar
Garage: 2001 M5 in Jet Black
$1k for a heat exchanger, some hoses and adapters, please tell me you're joking
2001 Jet Black///M5
Supersprint Headers, Race Cats, X-pipe, and Magnum mufflers, Dinan CAI, High flow MAF housings, Stage 4 Software, Ground Control suspension, Stoptech ST-40 BBK, Umnitza Predator Thinline demon eyes, Zionsville Super Duty Radiotor/Fan system, UUC short shift kit, Dinan brake duct kit, Odyssey lightweight battery, V1 w/ Stealth One, Blinder
1998 Cosmos Black ///M3
OEM LTW wheels, M50 manifold conversion and cold air intake, Stromung cat back exhaust, waiting to be installed: Ground Control coilovers/adjustable camber plates, SPC adjustable rear lower control arms, factory RTABS w/ GC shims, UUC Ultimate FCABs, new OEM front control arms, HMS motorsport reciever hitch, Michelin P/S A/Ss, factory motor mounts, UUC transmission mounts w/ enforcers, Sparco harness bar.
1985 Jeep CJ-7
Too much to list...
RIP
1995 Avus Blue ///M3
1997 TiAg ///M3
1986 Toyota HiLux 4x4
1979 Jeep CJ-7
Machtig is offline
Old 13th December 2006, 20:20   #30
mottati
mottati's Avatar
I'm open to suggestions if you have a link to the parts required to do this less expensively. It seems that one issue is taping into the oil filter lines, which are not a standard off the shelf part. Compared the the $4000 dinan oil cooler, i thought 1k seemed pretty reasonable. Other bmw vendors sell kits for 'simpler' cars, like the US E36 M3 for the $500-800 range.
personally, i haven't been getting to the track much lately, so this has become pretty low priority for me.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Best source for 10-60 synthetic?? CBarton E39 M5 and E52 Z8 Discussion 18 25th February 2006 03:30
Dipstick question unfoundhorsepower E60 M5 and E61 M5 Touring Discussion 7 11th February 2006 18:37
Help - Oil From Somewhere x703jko E39 M5 and E52 Z8 Discussion 9 27th December 2004 15:03
How Much $$ Do You Pay for an Oil Change?? cohenfive E39 M5 and E52 Z8 Discussion 31 4th September 2004 03:28
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.17968 seconds with 12 queries
