Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > BMW M5, M5 Touring, M6 and Z8 Forums > E39 M5 and E52 Z8 Discussion > M5 E39 Group Buy Forum and Sponsor Discussion and Offerings
Old 6th October 2009, 06:46   #91
herrubermensch
herrubermensch's Avatar
Garage: LeMans Blue 2001 BMW M5 with black and blue extended leather and brushed aluminum trim
Sales Feedback: (3)
Send a message via Yahoo to herrubermensch
I am told that the housing accepts M22 connectors, which sounds and looks correct. I'm going to order some AN10 to M22 connectors and confirm.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Dinan 3.45 Differential, GC Coilovers (550 Front/325 Rear), Dinan Front and Rear Swaybars, Dinan Monoballs, Dinan Wheels (18 x 9 Front/18 x 9.5 Rear), Bridgestone RE050 RFTs (275 Front/285 Rear), UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, Zionsville Super Duty Cooling System, OKD Plasma Ignition Coils and Plug Boots, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Custom Stereo Using Stock HU, PLX Digital Gauge, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, Schroth 4-Pt Street Harnesses, and Various Other Bits and Pieces
Coming Soon!
Stoptech "Trophy" Brakes, TC Designs Roll Bar, TC Designs Rear Sway Bar Brackets, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, Rogue Stage 3 280mm Clutch with JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement and Dinan Foglight Deletion Kit.
When the Motor Blows
Balanced and Blueprinted S62
herrubermensch is online now
Old 6th October 2009, 08:16   #92
E55AMG2
E55AMG2's Avatar
Pics of the Dinan block off kit plz
E55AMG2 is offline
Old 10th October 2009, 23:33   #93
herrubermensch
Sales Feedback: (3)
Originally Posted by gsfent View Post
I haven't tracked the car, but during the hot months, it seems to work fine. I note the 90 C degree T stat (built into the oil filter housing IIRC) seems to work, although there is a bit of delay from the reading to the opening. Seems to open closer to 98 or 99, then temp drops about 10 degrees almost immediately. Installer surmises simply slow reaction of the temp sensor to actual temps, but in all other respects, I have no issues.
Jerry:
I am just about to finish the removal of the under-plenum heat exchanger and the installation of the block-off kit, after which I'm forging ahead with the installation of the "Gulf" housing and a 16-row oil cooler behind the kidneys. One thing I noticed on the thermostat valve in the housing is the imprint "100 [degree symbol]". From this, I think the thermostat doesn't open until 212 degrees Fahrenheit, which sounds like it is consistent with your experience.
--Peter
The Beast
Coming Soon!
The Following User Says Thank You to herrubermensch For This Useful Post:
gsfent (11th October 2009)
Old 11th October 2009, 08:46   #94
E55AMG2
E55AMG2's Avatar
I really do need to get rid of that exchanger....heatsoak really sucks on track days
E55AMG2 is offline
Old 11th October 2009, 11:29   #95
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
If it opens at 100C, and the temps drop 10C immediately, at what temp does it close? Does it cycle between 100 and 90?
John Baas
2001 Anthracite Metallic M5
Interior
Exterior
Drivetrain
Suspension
Coming Soon
xr4tic is offline
Old 11th October 2009, 18:11   #96
herrubermensch
Sales Feedback: (3)
Good question.
The Beast
Coming Soon!
Old 11th October 2009, 22:04   #97
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Not sure, I don't normally see oil temps that high. I would guess there is about a 10 degree spread. If on track, I would think the cooler would stay open after maybe one cycle as the oil and water keep the heat up so it would not cool enough to close the oil cooler.
However, in the interest of science, I will try to do some SC pulls with the car, solely to generate some oil heat so I can answer your question!
gsfent is offline
Old 29th October 2009, 13:16   #98
herrubermensch
Sales Feedback: (3)
--Peter
This is NOT correct; the M22 connectors are TOO SMALL. Trying an M30 this weekend.
--Peter
The Beast
Coming Soon!
Old 5th November 2009, 16:15   #99
alquazi
Garage: 2000 M5 Alpine White
So, did the M30 work?
'00 BMW ///M5 Alpine White
Mods
Chip Logic ECU tune
Schrick cams
Hamann Headers (High temperature coated inside and out)
Custom made exhaust (cat delet)
K&W Coilovers V3
WP Pro BBK (360 mm rotors, 8 pot calipers front, 6 pot calipers rear)
alquazi is offline
Old 7th November 2009, 16:11   #100
herrubermensch
Sales Feedback: (3)
No! They were too big! After trying four other adapter sizes, I finally found the right one: 26mm x 1.5! Whew. Here is the link so that noone else will have to buy $200 worth of fittings before they get the right one! Pegasus - 26mm Metric to AN Plumbing Adapters
Whew!
---Peter
The Beast
Coming Soon!
alquazi (10th November 2009)
Best source for 10-60 synthetic?? CBarton E39 M5 and E52 Z8 Discussion 18 25th February 2006 03:30
Dipstick question unfoundhorsepower E60 M5 and E61 M5 Touring Discussion 7 11th February 2006 18:37
Help - Oil From Somewhere x703jko E39 M5 and E52 Z8 Discussion 9 27th December 2004 15:03
How Much $$ Do You Pay for an Oil Change?? cohenfive E39 M5 and E52 Z8 Discussion 31 4th September 2004 03:28
Oil Facts And Myths DrRob E39 M5 and E52 Z8 Discussion 9 21st December 2001 23:20
Page generated in 0.11747 seconds with 12 queries
