Hey Apples,
I'm not going to tell you to change your clutch. But from reading the above post, it sounds like that would solve you problem.
When you get back to OZ., come and take Yoda for a Spin, and deceide for yourself. It would be good for another board member to give there independant appraisal of my clutch.
I had my first race yesterday with the new clutch. A HSV was in the right lane and I was in the left lane. My lane terminated on the other side of the lights, so it was a race to see who gets in front first.
I took off and was just pushed back hard in my seat with no wheel spin. I had plenty of revs that would have fried the stock clutch. I hit second and it gave a tiny Beep of the wheels and then I hit 3rd and again the same little beep and again in fourth.
The HSV was left in the dust, right from the start.
Now heres the kicker. DSC was ON.
I got a slight churp in each gear with DSC ON. Sport was OFF also.
I was at the drag strip once with the stock clutch and left DSC ON. When I hit 2nd it almost throughs me threw the windshield. It was like you go from 100% power to nothing, then a couple of pauses and a settle then your away again. Too much interference.
Now I want to test this some more, but it seems that with the new setup, it does not continue to be invasive.
The best way to describe it is like comparing a worn shock absorber to a stiff sports one. When you press on the stiff sports one it goes down and then returns to where it was. The worn stock one goes dowe then rises above where it was and then goes down again less and then settles to where it was.
DSC with the stock clutch was like the worn schocky. Whereas with the new setup it is like the Sports shocky, it intervenes momentarily then realises all is good and leaves it alone.
Its hard to explain, but its like stock DSC is a wave on a spring that pulses backwards and forwards. But now it just travels straight through and gone.
Its a great improvement. Its raining today.
I wanted to do some full blooded race launch burnouts. The clutch is run in enough now. 1,500Km Its smoother now as well.
