Thrust Arm Spherical bearings/monoballs (interested?) - Page 4 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E39 M5 and E52 Z8 Discussion > M5 E39 Group Buy Forum and Sponsor Discussion and Offerings
Like Tree42Likes
LinkBack Thread Tools Display Modes
Old 29th March 2012, 15:47   #31
josiahg52
josiahg52's Avatar
Garage: 2001 Jet Black/All Exclusive Black/Black Cubic M5, Supercharged 2001 Tahoe LT 4x4
Sales Feedback: (6)
1) checock
2) josiahg52
Thank you.
Sent from my Samsung Galaxy S™ II, Epic™ 4G Touch using Tapatalk
-Josiah
2001 ///M5 Jet Black/All Exclusive Black/Black Cubic - 3/2001 production "UNTIER"
josiahg52 is online now   Reply With Quote
Old 29th March 2012, 16:40   #32
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
Originally Posted by gsfent View Post
Matt
I have some interest with a little more info.
I am very happy with my X5 bushings as part of my Dinan stage 3 suspension. It is a perfect daily driver. With your bushings, I would expect less flex and a little better turn in for hard or track drivng. But how much harsher will it be in everyday street driving?
The car is primarily a street car, so I am sensitive to maintaining a comfortable ride when I transport people.
The dinans are cushy soft in terms of nvh Oddly enough. I'd expect the same from these.
E55AMG2 is online now   Reply With Quote
Old 29th March 2012, 18:52   #33
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
Not my experience with the Dinan monoballs. Ride quality is unaffected, but high frequency noise/harshness from stuff like Botts lane markers or broken pavement is significantly increased. Note I have the Ground Control camber plates which feature a stiffer/harder rubber mount, so I think it's the combo of the two that makes it so noticeable, but the monoballs were the last thing I added, so the change was immediately noticeable (this was about 4 years and ~10k miles ago). If I still had the stock front upper strut mount, I bet the NVH difference would be minimal.
Performance-wise they are superb. Turn-in is sharper and more precise feeling, you get a better sense of the front tire's contact patch communication on stuff like heavy trail-braking and then turn-in, especially with R-comp tires mounted up. That aspect of the monoball change is really enjoyable.
Current stable:
Dinan: springs, Konis, rear sway bar, monoball bushings, and exhaust;
Ground Control camber plates, Stoptech front BBK, Brake ducts opened,
Evolve AlphaN tune,
OE 9.5" rear wheels all around & 275/35-18 Pilot Super Sport
2011 M3 sedan 6MT Silverstone, no sunroof!
1996 Volvo 850R wagon
herd has been thinned, looking for some new acquisitions...non-sunroof E90 M3 = found
CSBM5 is offline   Reply With Quote
The Following User Says Thank You to CSBM5 For This Useful Post:
mattmartindrift (13th April 2012)
Old 29th March 2012, 19:51   #34
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
I have steel spherical pillow ball mounts, and NVH was virtually unaffected. I've noticed that tire choice does make a more significant difference in NVH now though.
Old 29th March 2012, 20:23   #35
CSBM5
CSBM5's Avatar
I know we've always had a difference of opinion/experience on this issue, and I can't explain it. Definitely agree on tires though -- PSS make a huge difference in reduced NVH from the Star Specs, both on my M5 and E46.
Old 29th March 2012, 20:25   #36
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
You could build a skyscraper on the sidewalls of the starspec...but boy did they sure grip nicely
Old 29th March 2012, 20:30   #37
Trouble
Trouble's Avatar
Garage: '01 M5 Carbonschwarz Metallic
I have some interest in your mono balls... sent you a PM via ZT.
Trouble is offline   Reply With Quote
Old 29th March 2012, 20:31   #38
CSBM5
CSBM5's Avatar
PSS were awesome in 55F temps a couple of weekends ago...was able to PAX in the ZHP within 0.9 seconds of the H-stock National Champion which only barely is an STX car (just a rear sway bar and 8.5" front wheels puts it out of stock class). I think the cool temps really played in their favor as I was amazed at the grip and feedback. Other STX competitors in better prepared cars were all on Star Specs I think.
Old 29th March 2012, 20:35   #39
E55AMG2
Moderator Emeritus
E55AMG2's Avatar
Yeah, they (starspec) dont like cold. Sub 40 degrees, they slide around noticeably until you scrub them in very hard. No such issue with PSS..same goes for flat-spotting after being driven on hot tarmac.
Old 30th March 2012, 02:21   #40
xr4tic
xr4tic's Avatar
Garage: 2001 Anthracite M5
Sales Feedback: (4)
Originally Posted by mattmartindrift View Post
Thanks for the feedback!! Sometimes it can be hard to find an unbiased review of expensive parts - the 'ol brain-wallet bias often takes hold.
With your Kelleners springs, have you changed the shocks to account for the altered ride height? It is my understanding that the monoballs remove some spring rate and damping from up front due to the now-unrestricted movement about the axis of the thrust arm bushing/bearing - as the bushing flexes the spring rate would increase (within the normal range of motion), similar to a urethane bump stop, without the harshness (you've got a 15" lever atached).
Folks have reported slightly lower ride heights after doing monoball installs, and that may be causing you to hit the bump stops?
Still running the stock shocks, I was planning on replacing them with coilovers, just haven't got around to it yet. Being undecided on the brand doesn't help.
If it's lower, it's not by much. I still have a 1 finger gap between the tire and the fender lip with stock rims/tires, so it's not excessively low. Any lower and I can't get into my driveway without scraping.
As far as NVH goes, noise and vibration are fine, barely there, it's the harshness. The worst is my street, where the concrete slabs are uneven. If you have decent streets it will probably be OK, but around here, there is the occasional stretch of road that is really bad, and I start seriously thinking about getting some X5 bushings.
John Baas
2001 Anthracite Metallic M5
2003 Silverado SS
Interior
Euro Dash, Slimmbones Euro Armrest, UUC EVO3 Shifter, UUC DSSR, UUC Clutch Stop, Autolumination Interior LEDS, JBL MS-8, Zed Audio Amplifiers (DSP Removed), Polk Subwoofers, Polk/Boston Acoustic Speakers
Exterior
Vosteiner Power Dome CF Hood, Euro Clear Corner Headlights w/Lamin-X, Umnitza Predator Ice V3, Umnitza 6K Headlight + Fog Light Upgrade, Umnitza V4 Side/Turn/License LEDs, CF Roundels, Black Kidney Grills, Slimmbones BigMouth Lower Grill, Slimmbones Rear Diffuser
Drivetrain
Evolve Alpha-N Tuning, Supersprint Headers/Cats/X-pipe + Eisenmann Race Mufflers, VSL Aluminum Radiator, UUC Twin Disk Clutch
Suspension
Dinan Monoballs, Kellener's Lowering Springs, Black Stock Rims Square Setup
Coming Soon
Alex S. Monoballs, Custom CAI, Custom Oil Catch Cans
My CarPC Blog
xr4tic is offline   Reply With Quote
Group buy for spherical bearing upper control arm bearings mooseheadm5 M5 E34 Group Buy Forum and Sponsor Discussion and Offerings 6 10th February 2011 02:14
Group buy for spherical bearing upper control arm bearings mooseheadm5 E28 M5 Discussion 15 14th January 2011 22:20
Thrust arm bushes replaced and new track contol arm, massive difference! Rog E39 M5 and E52 Z8 Discussion 0 19th August 2010 23:14
X5 Heavy Duty Thrust Arm/Upper Control Arm Bushings For Sale gmakishima Parts / Other For Sale or Wanted 2 24th May 2007 19:12
Thrust Arm Bearings--X5 or Powerflex drabe E39 M5 and E52 Z8 Discussion 5 28th March 2006 19:22
