Thrust Arm Spherical bearings/monoballs (interested?) - Page 16 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E39 M5 and E52 Z8 Discussion > M5 E39 Group Buy Forum and Sponsor Discussion and Offerings
Like Tree42Likes
LinkBack Thread Tools Display Modes
Old 14th June 2012, 13:53   #151
lugnuts
lugnuts's Avatar
Garage: 2002 LeMans Blue M5 _______1979 Trans Am_____
Originally Posted by josiahg52 View Post
I bet if you packed the bearing pocket with a grease like tourmaline, class 2 technical petrolatum or a Mobilgrease XHP grease you would provide adequate protection. Actually, any soap based grease may work. The goal would be to fill it and maintain a barrier from dirt and moisture. Most high drop point grease would be suitable. Just some thoughts.
Sent from my Samsung Galaxy S™ II, Epic™ 4G Touch (Sprint) using Tapatalk 2
grease is not needed on these as they are self lubricating. the other thing with grease is it will attract dirt.
lugnuts is offline   Reply With Quote
Old 14th June 2012, 14:37   #152
josiahg52
josiahg52's Avatar
Garage: 2001 Jet Black/All Exclusive Black/Black Cubic M5, Supercharged 2001 Tahoe LT 4x4
Sales Feedback: (6)
If there is enough grease with a good drop point, good adhesion characteristics and with sufficient water resistance the dirt won't reach the bearing and the dirt on the surface won't matter. I am not recommending it but I think it is a much better way to keep dirt away from the bearing then a dust cover which could be voided and you not even know it. My plan is to thouroughly clean the bearing before installation and rely on the Teflon liners. That is what they are there for.
-Josiah
2001 ///M5 Jet Black/All Exclusive Black/Black Cubic - 3/2001 production "UNTIER"
josiahg52 is offline   Reply With Quote
Old 16th June 2012, 04:04   #153
sarodom
Garage: Black M5
I am interested in a set of these, are they still available?
sarodom is offline   Reply With Quote
Old 29th June 2012, 18:23   #154
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
No more reviews!?
I know there are a handful of sets floating around out there.
I have >3k miles on mine and still as good as day 1.
But no one cares about the manufacturer's own review!!!
mattmartindrift is online now   Reply With Quote
Old 29th June 2012, 18:43   #155
mattmartindrift
Garage: 540i
also, here are instructions:
http://mattmartindrift.com/E39/monob...structions.pdf
I have put them on my website, as well as attached them here.
Old 29th June 2012, 19:01   #156
josiahg52
josiahg52's Avatar
Sales Feedback: (6)
Sorry Matt!
Background:
At the same time I installed these I also installed Powerflex sway-bar bushings and Li Customs adjustable sway-bar end-links. These spherical bearings were installed in NEW Lemforder thrust arms. Ultimately, I decided to install them in new arms simply for ease of re-installation and so I would not be bothered in saving the ball joint/boot or having to press out the OEM bushing.
My car has 98k miles on it, GC coilovers (430/340#) and is running square OEM wheels with PSSs. It turns out that I needed a new thrust arm or, at a minimum, a bushing on the right side as the old bushing was worn to the point that the tire was rubbing slightly when at full right lock. Both bushings appeared fine once they were removed from the car and there was never any noticeable affects under heavy braking.
Fit/Fitment:
They of course fit with zero rework required on my end. They were installed in about 45 minutes and I had everything buttoned up on the front end in about an hour.
Appearance/Quality:
Top notch and they are really beautiful in person. I am PROUD to have these on my car and to deal with Matt is truly a pleasure. I will not hesitate in purchasing the matching REAR set when they are ready. (hint, hint!)
Review:
After approximately 400 miles of various driving scenarios over wide ranging surfaces such as uneven pavement, rumble strips, expansion joints, potholes, broken cement/pavement, metal grate bridge decking, smooth high speed surfaces, rural roads, grooved freeways/highways, I can honestly say that the ride is unremarkable. What I mean by unremarkable is that in general driving, I do not think that you could tell the difference unless you were really trying.
That is to say, the basic ride quality/demeanor is not affected and I do not notice any additional "jarring" or "shock" events from surface imperfections or design elements than I did before the install. I truly believe that this is due to, in part at least, the superior ride quality afforded by the Koni/Eibach setup I am using. I do notice some "noise" on various road surfaces but it is not detrimental to the overall experience nor does it annoy me and it is REALLY hard to say that it is any more present than before. I had to really take a day of driving and actually "look" for these differences, as they are not glaringly apparent at all, in the slightest.
The big difference, one that I was not expecting so, is how much sharper turn-in and steering feel is after the install. There must be more play in the OEM bushings than I expected but the car instantly responds to minor steering inputs but not in an intrusive, excessive or dangerous way.
Overall:
So, obviously they are better than that(those) apparently worn bushing(s) but the entire car feels better than my last M5 did and that M5 had had a COMPLETE (I mean COMPLETE) suspension refresh about 8k miles before I got it.
I truly was expecting a drastic change in ride quality (for the worse) based on some of the reviews that I had read concerning monoball installations even on cars other than the E39. The change is hardly drastic as far as ride quality is concerned. It really only makes the car better, not different.
The benefits of these monoballs that I see looking forward:
1) The thrust arms become infinitely serviceable limited only by the life of the ball joint.
2) The bearings themselves are replaceable, serviceable in your garage or driveway, cheaper than purchasing an entire thrust arm(s) and require less maintenance to replace than R/Ring the thrust arm(s) in whole.
3) The car will feel the way it feels now for a lot longer than with the OEM thrust arm and will not suffer at the hands of a failing thrust arm bushing again.
I LOVE them. They definitely improved the response and feel of the car and I highly recommend them.
Last edited by josiahg52; 29th June 2012 at 22:41. Reason: additional information and clarification
The Following User Says Thank You to josiahg52 For This Useful Post:
herrubermensch (29th June 2012)
Old 29th June 2012, 19:46   #157
Diny
Diny's Avatar
Garage: Anthracite M5
Sales Feedback: (25)
Do the thrust arms need to be changed themselves? Mine were changed 60k miles ago. Would I need to get new ones to match with these or will the old ones be just fine?
Fighting Oil Threads since 2007
Diny is online now   Reply With Quote
Old 29th June 2012, 19:54   #158
bmwMcrzy
bmwMcrzy's Avatar
Garage: 02 Le Mans Blue / Caramel DINAN S2
As long as your ball joints are in good shape, just press out the stock bushing
bmwMcrzy is online now   Reply With Quote
Old 29th June 2012, 20:01   #159
mattmartindrift
Garage: 540i
bmwMcrzy is correct.
Press out the old bushings, and install these - simple as that. The OEM/Lemforder ball joints seem to last >150k when the boots are kept in good condition.
Old 29th June 2012, 21:01   #160
PaulRuffo
PaulRuffo's Avatar
Garage: 00 Ti Silver M5
Sorry Matt, life has been busy, so they are still in the box. As soon as I get them installed I will definitely post a review. I showed them to a few fellow gear-heads who were impressed at the quality of the product.
Thoughts on using this "in-car" procedure rather than taking the control arm off the car?
http://www.beisansystems.com/procedu..._procedure.htm
PaulRuffo is offline   Reply With Quote
Group buy for spherical bearing upper control arm bearings mooseheadm5 M5 E34 Group Buy Forum and Sponsor Discussion and Offerings 6 10th February 2011 02:14
Group buy for spherical bearing upper control arm bearings mooseheadm5 E28 M5 Discussion 15 14th January 2011 22:20
Thrust arm bushes replaced and new track contol arm, massive difference! Rog E39 M5 and E52 Z8 Discussion 0 19th August 2010 23:14
X5 Heavy Duty Thrust Arm/Upper Control Arm Bushings For Sale gmakishima Parts / Other For Sale or Wanted 2 24th May 2007 19:12
Thrust Arm Bearings--X5 or Powerflex drabe E39 M5 and E52 Z8 Discussion 5 28th March 2006 19:22
