Thrust Arm Spherical bearings/monoballs (interested?) - Page 13 - BMW M5 Forum and M6 Forums
Go Back   BMW M5 Forum and M6 Forums > BMW M5, M5 Touring, M6 and Z8 Forums > E39 M5 and E52 Z8 Discussion > M5 E39 Group Buy Forum and Sponsor Discussion and Offerings
Like Tree42Likes
LinkBack Thread Tools Display Modes
Old 4th June 2012, 12:08   #121
Mach5M5
Mach5M5's Avatar
Garage: 2001 M5 Silver
Looking forward to trying these out at that track this summer.
Matt, PM sent.
Doug
2001 Ti Silver Build date 01/01 currently 92,500 kms
Acquired 09/09/28 from original owner. Currently my sunny day and track toy.
Fixes and PM
Thermostat, temp sender, fan clutch, rad hoses, engine mounts, trans mounts, center bearing, tailight seals, belts, PS hoses,
center link, tie rods, thrust and control arms, front and rear sway bar links, RMS and Clutch (stock), Vanos solenoids, alternator rebuild, idler pulleys,
oil pan drain plug timesert.
Upgrades
E60 shifter
Bilstein PSS9 with GC Camber Plates
Custom CAI
Custom M5 grill with brake cooling ducts
Stoptech ST 40 / Stoptech rear pads Stoptech STR660 fluid
Michelin PSS 265 on 9.5s w 12mm spacers (front) Stock 275 on the rear
Mattmartin monoballs
Evolve Alpha N
Mach5M5 is offline   Reply With Quote
Old 5th June 2012, 20:57   #122
PaulRuffo
PaulRuffo's Avatar
Garage: 00 Ti Silver M5
Are you guys going to press these in with a balljoint style press (like you can rent from Autozone), or bring them to a shop to have them pressed in with a hydraulic press? I am leaning toward the latter, but wanted to see what the consensus is.
Thanks,
Paul
PaulRuffo is offline   Reply With Quote
Old 5th June 2012, 21:10   #123
josiahg52
josiahg52's Avatar
Garage: 2001 M5
Sales Feedback: (6)
Thanks,
Paul
There is no pressing required except to get the OEM bushing out of your new (or used) arms.
The receiver and bearing are held in place via an interference (or press) fit and should be able to be assembled by hand. That is an additional benefit (IMO) of this assembly: easier to service and cheaper, limited in terms of reuse only by the life of the ball-joint.
2001 Jet Black
josiahg52 is offline   Reply With Quote
Old 5th June 2012, 21:47   #124
PaulRuffo
PaulRuffo's Avatar
Excellent! I had assumed that the receiver had to be pressed into the arm. Thanks for setting me straight.
Paul
Old 6th June 2012, 15:17   #125
mattmartindrift
mattmartindrift's Avatar
Garage: 540i
Sorry gents, I meant to get these shipped by now. We had a nasty stomach virus rip through the family and knock us all off of our feet for four days. I should be sending a handful out today.
mattmartindrift is online now   Reply With Quote
Old 6th June 2012, 17:21   #126
PaulRuffo
PaulRuffo's Avatar
No Worries. Thanks for the update Matt.
Old 6th June 2012, 17:42   #127
josiahg52
josiahg52's Avatar
Garage: 2001 M5
Sales Feedback: (6)
As long as you guys are okay, Matt! Thank you for the update.
Old 6th June 2012, 18:04   #128
Checock
Checock's Avatar
Garage: 2001 LeMans Blue M5; 2006 Dodge Ram 2500 Cummins
Good to hear you're doing better.
Checock is offline   Reply With Quote
Old 7th June 2012, 13:47   #129
josiahg52
josiahg52's Avatar
Garage: 2001 M5
Sales Feedback: (6)
Well, I broke down and bought the BMW ball-joint separator. Yeah, it's expensive but if I bought one of the other tools and it broke or didn't work for some reason . . . I don't think I could handle that right now. Hopefully by spending some money on a tool like this I assure that it will work for me the first time. I still have some other work to do on the car while I'm waiting for my new arms to arrive anyway.
Old 8th June 2012, 01:12   #130
PaulRuffo
PaulRuffo's Avatar
I was planning on re-using the arms on there as I think the ball joints are fine. I'll check them when I pull it apart. Anyone else planning to do the same? I figured if I could save a couple hundred bucks I would, but maybe I'm making a poor choice...
Thoughts?
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
reds2
Group buy for spherical bearing upper control arm bearings mooseheadm5 M5 E34 Group Buy Forum and Sponsor Discussion and Offerings 6 10th February 2011 02:14
Group buy for spherical bearing upper control arm bearings mooseheadm5 E28 M5 Discussion 15 14th January 2011 22:20
Thrust arm bushes replaced and new track contol arm, massive difference! Rog E39 M5 and E52 Z8 Discussion 0 19th August 2010 23:14
X5 Heavy Duty Thrust Arm/Upper Control Arm Bushings For Sale gmakishima Parts / Other For Sale or Wanted 2 24th May 2007 19:12
Thrust Arm Bearings--X5 or Powerflex drabe E39 M5 and E52 Z8 Discussion 5 28th March 2006 19:22
