14th April 2011, 21:06
#445
2003 M5 matte black
Originally Posted by JDMM5
Another question: What about modifications to the underbody heat shields? Will there need to be any cutting, trimming, etc. of the aluminum sheetmetal anywhere?
I remember reading on other forums about there being significant mods needed with some other manufacturers header systems such as trimming and in some cases deletion of the heat shields altogether in some areas. I want to avoid this if possible, and if necessary I'll be prepared to have so custom pieces fabricated.
No modifications needed!
-rebuild in winter 2011/2012
-"submarine edition",a bit boost and some M5 parts...
