Roy, thanks for this GB, which is very reasonable when you consider it is essentially the same as the ESS kit PLUS an intercooler AND an oil cooler. I opted for the ESS kit because with the ESS GB price, I was able to add water/meth injection and a Rogue Stage 3 280MM clutch and JB LTW flywheel all for about what the CA SC kit costs. When I added the RMS intercooler, however, the overall cost shot up to about $15k. Upshot: If you want a SC kit with an intercooler, the CA kit is a great deal, particularly at the GB price. If you are willing to run without one, the ESS kit is cheaper.
--Peter
The Beast
2001 E39 M5 LeMans Blue with Black/Blue Sport Interior and Titanium Trim, ESS Supercharger, RMS In-Plenum Intercooler, RMS Plenum Plates and Custom-Bored 52mm Diameter "Shorty" Velocity Stacks, Dinan TBs and Headers, CNS Catback Exhaust, Evosport High-Flow Cats, Stoptech Trophy Sport Brakes (6-Pot Front/4-Pot Rear; 355 mm Rotors All Around), Dinan 3.45 Differential, Dinan LTW Flywheel, GC Coilovers (550 7" Front/325 10" Rear), Dinan Front and Rear Swaybars, Dinan Monoballs, Dinan Rear Wheels (18 x 9.5) All Around With 10mm Spacers and 90mm Wheel Studs, Michelin PS2s 275 35 18s All Around, UUC EVO3 SSK with DSSR, Voltphreaks VPR-S40P Endurance Battery (14 lbs.), Setrab 16-Row Oil Cooler, Dinan Under-Plenum Heat Exchanger Removal Kit, Vorsteiner Double-Sided CF Hood with Open Vents, CA CSL-Style CF Trunk Lid, Zionsville Super Duty Cooling System, Aquamist HFS-6 Meth Injection with Custom CF/Aluminum Trunk-Mounted Fuel Cell Designed by Howerton Engineering, XRP HS-79 Hosing, OKD Plasma Ignition Coils and Plug Boots, Smoked Hella Tailights, Clear-Corner Hella Euro Headlights, CA ACS-Style CF Front Splitters, Custom Stereo Using Stock HU, PLX Digital Gauges, V1/S1 Mounted in UGDO Location, Recaro Sportster CS Seats, Schroth 4-Pt Street Harnesses, Dinan Foglight Delete Kit, and Various Other Bits and Pieces
Coming Soon!
Hankook R-S3 285 35 18s All Around, EAS Competition Steering Wheel, TC Designs Roll Bar, Leather Eurodash, Full Leather Doorcards, TC Designs Rear Sway Bar Brackets, Rogue Stage 3 280mm Clutch with JB Racing LTW Flywheel, Dinan Differential Subframe Reinforcement, Stoptech Carbon Ceramic Rotors, Quad Head Laser Interceptor, Kenne Bell Boost-A-Pump
When the Motor Blows
Balanced and Blueprinted S62
