Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 15th October 2001, 23:43   #1
1C00lVC
1C00lVC's Avatar
Garage: '01 Ti/silver E39 M5
Send a message via AIM to 1C00lVC Send a message via Yahoo to 1C00lVC Send a message via Skype™ to 1C00lVC
DSP wiring pinout
2000 DSP Premium Sound connector information
The pinouts for the 15 pin connector are:
PIN - CONNECTION
1- Sub 1 +
2- Sub 2 +
3- LH Rear loudspeaker + (Touring LH rear speaker ground)
4- Radio on/antenna signal
5- RH rear loudspeaker + (Touring RH rear +)
6- Sub 4 -
7- Sub 3 -
8- Terminal 30 connects to Fuse 56
9- Sub 1 -
10- Sub 2 -
11- Touring LH rear +
12- Touring RH rear -
13- Sub 4 +
14- Sub 3 +
15- Terminal 31 connects to Ground Point
The pinouts for the 18 pin connector are:
PIN - CONNECTION
1- Not used
2- Low freq. negative (-) signal - Transceiver/charging electronics
3- Not used
4- Not used
5- I-bus Signal Line - Splice X18344
6- Not used
7- Not used
8- RH front speaker - Connects to Radio
9- LH front speaker - Connects to Radio
10-Not used
11 Low freq. voltage (+) signal - Transceiver/charging electronics
12-Not used
13-Telephone mute signal - Transceiver/charging electronics
14-Not used
15-Telephone ON signal - Transceiver/charging electronics
16-Not used
17-RH front speaker + - Connects to Radio
18-LH front speaker + - Connects to Radio
The pinouts for the 26 pin connector are:
PIN - CONNECTION
1- LH front woofer +
2- LH front woofer -
3- Not used
4- RH front mid-range -
5- LH front mid-range +
6- Not used
7- Not used
8- Not used
9- RH front mid-range +
10-LH front mid-range -
11-Right rear mid-range speaker/tweeter +
12-RH front tweeter +
13-RH front woofer +
14-LH front tweeter +
15 LH front tweeter -
16-Left rear mid-range speaker/tweeter -
17-Not used
18-Not used
19-Left rear mid-range speaker/tweeter +
20-Not used
21-Not used
22-Not used
23-Not used
24-Right rear mid-range speaker/tweeter -
25-RH front tweeter -
26 RH front woofer -
1C00lVC is offline
Old 14th July 2002, 07:50   #2
Bluewater M5
Bluewater M5's Avatar
Garage: infiniti qx4
I have a 2002 M5 and check out all the colors of the wires. So here they are.
12 Pin Female (plugs into stock Nokia box)
Pin 1 = blank
Pin 2 = blue w/ white stripe (SUB 1 +)
Pin 3 = blue w/ brown stripe (SUB 1 -)
Pin 4 = yellow w/ black stripe (SUB 2+)
Pin 5 = yellow w/ grey stripe (SUB 2 -)
Pin 6 = blank
Pin 7 = blank
Pin 8 = yellow w/ red stripe (SUB 3 +)
Pin 9 = grey w/ brown stripe (SUB 3 - )
Pin 10 = yellow w/ white stripe (SUB 4 +)
Pin 11 = yellow w/ brown stripe (SUB 4 -)
Pin 12 = blank
15 Pin Female (plugs into the stock amp)
Pin 1 = blue w/ white stripe (SUB 1 +)
Pin 2 = yellow w/ black stripe (SUB 2 +)
Pin 3 =
Pin 4 = WHITE (radio on/antenna)
Pin 5 =
Pin 6 = yellow w/ brown stripe (SUB 4 -)
Pin 7 = grey w/ brown stripe (SUB 3 -)
Pin 8
Pin 9 = blue w/ brown stripe (SUB 1 -)
Pin 10 = yellow w/ grey stripe (SUB 2 -)
Pin 11
Pin 12
Pin 13 = yellow w/ white stripe (SUB 4 +)
Pin 14 = yellow w/ red stripe (SUB 3 +)
Pin 15 = brown (ground)
Jimmy
2002 M5 Bluewater (sold)
Luxury with Bruyere trim
Supersprint X-pipe on stock exhaust
Bluewater M5 is offline
Old 19th September 2003, 10:41   #3
warhaven
warhaven's Avatar
Garage: 2002 M5 Jet Black
Speaking of the DSP system. Bought my E39 a year old and the origional owner didn't elect to install a DSP system just the normal radio. Is it worth investigating an upgrade to a DSP unit? If so how does one go about upgrading?
warhaven is offline
Old 30th September 2004, 05:09   #4
Sparky5series
Garage: 2000 Carbon M5
Re: DSP wiring pinout
Save yourself the trouble and just forget about "upgrading" to DSP. I'd start looking into aftermarket audio. Diamond audio is supposed to be pretty good, and MB Quart has an excellent component system for the M5, if you have at least 4 grand to dump into it. I'm in the process of upgrading my DSP and I'm pulling my hair out. Maybe I can be of help since I'm only about an hour from you.
Sparky5series is offline
Wiring pinout? Pelle Off Topic Forum 2 26th November 2002 14:45
Tech: need subwoofer wiring help on DSP Audio Teutonaddict E39 M5 and E52 Z8 Discussion 19 14th July 2002 18:27
Interminent problem with DSP DDL E39 M5 and E52 Z8 Discussion 10 13th March 2002 07:18
DSP Settings 1C00lVC M5 E39 and E60 tips & tricks 0 15th July 2001 02:25
Page generated in 0.13614 seconds with 11 queries
