Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 25th March 2007, 11:44   #1
V8PBN
Garage: E39 M5 Silverstone Blue
e39 Engine Warning Light
Hi Guys, just taken delivery of a mint 2001 with 40K miles on clock. Had a BMW Main Agent change engine oil yesterday and this morning (cold start) the engine warning light has come on (Yellow). Its in for a check at the same main agent next week. Runs fine although tail pipes seem a little black. Any ideas / suggestion? Thanks Paul
V8PBN is offline
Old 26th March 2007, 19:06   #2
SeeSure
Garage: M5 Le Mans Blue
Check for a loose fuel filler cap. (Can trigger the SES light)
If that doesn't solve it then get the codes pulled by the dealer or a good Indy.
Odds are it will be a sensor (O2 or CPS) maybe a MAF.
As the car normally runs rich on start up you should be okay
and black tail pipes is normal, unless you take a bit of elbow
grease to them and polish them up. As long as you don't have
a permanent smoke trail you should be fine.
Why is the slowest person always at the front of the queue ???
SeeSure is offline
Old 21st August 2008, 14:23   #3
Ted
Ted's Avatar
Garage: 2001 M5 Jet Black/Black
Sales Feedback: (6)
Did you resolve this?
2009 Toyota Tundra TRD Black/Gray
Tomtom Go 720 Navigation with Bluetooth
2008 Toyota Highlander Black/Gray
Still searching for a reliable race car...
"The car is the closest thing we will ever create to something that is alive"
Ted is offline
Specifications of every BMW Der Abt Off Topic Forum 10 7th June 2008 15:16
M5/M6 V10 a success in Australia Just_me E60 M5 and E61 M5 Touring Discussion 1 16th November 2006 00:53
Bet You Never Got a Check Engine Light for This Reason! MAH E39 M5 and E52 Z8 Discussion 13 23rd June 2005 21:36
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 15th December 2004 22:25
More engine Pics Black M5 E60 M5 and E61 M5 Touring Discussion 2 28th June 2004 23:38
Page generated in 0.08945 seconds with 11 queries
