After reading the list again, I am not so sure that I understand all of the items. Can you guys have one more go at it, please?
1. Anti theft system.
- Set by door lock or set by remote control
How to set the alarm. We choose if done by remote or key?
2. Visual arm / disarm. on/off
Flashing of 4 way flasher lights to indicate alarm is armed or disarmed. Choose if this happens or not?
3. Power locks.
- Remote control of interior lights on/off.
Want light to go on when unlock doors by remote?
- Autolock after 2 min on/off
Locks the doors after 2 min? or not?
- Autolock on drive away (5mph) on/off
Lock the doors on drive away, or not?
- Selective door locks ie: one press opens drivers door only double press opens all doors and boot (trunk)
This one is clear.
4. Window and roof controls.
- One touch is selectable for each door and the roof independently; open and/or closed. (think about this before asking questions)
- Total closer from remote on/off
- total or partial opener from remote on/off
I think I have this, too.
5. interior light soft on or off on/off.
Is this whether the lights dim slowly or just go off all at once?
6.External lights.
- DRL on/off
Daytime running lights - thanks Anzir.
- Home lights on/off/40s/90s/150s/240s
Headlights stay on after engine off. Thanks 1coolvc.
7.Accoustic warnings key on/off
What is this?
8. Heating A/C and vent settings key seletive on/off by key 1/2.
If there are two drivers, the car will remember that I like 69 degrees and fresh air? Will it know that the other key is in the safe? Yeh, right. Two drivers - not!
9.Flaps recirc. air memory on/off
What's this?
10.A/C Cooling output high/low
Does this set a default for the fan setting? Doesn't the setting just stay the same as last use?
11. Seat/mirror memory when unlocking/when opening door on/off.
Is this like pushing the memory button on the door on other models? Why does this matter?
12. PDC volume 1-6 and switch on message on/off.
What is this, guys?
3. Power locks.
This one is clear.
6.External lights.
- DRL on/off
What is this?
What's this?
What is this, guys?
