Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 25th November 2005, 00:50   #1
Need4Spd
Need4Spd's Avatar
Tip for Making it Easier to Replace Front Turn Signal Bulbs
I don't know about you, but I've had to change far too many front turn signal bulbs. They seem to go out once a year while the rest of the bulbs are original and still working! Go figure, since the side and rear bulbs blink at the same time as the fronts.
The space for reaching in and unplugging the bulb holder is very tight, and to make matters worse, the holder is often stuck because of the passage of time, elements, etc. This often means, as discussed in other threads, removing the entire headlamp assembly or at least the air cleaner to get at the bulb.
Well, that's just too much work for a simple bulb change. While I can just barely reach the bulb holder, I don't have enough space or leverage to un-do the holder from its socket. So the thought occurred to me, why not grease them a bit?
But not just with just any grease. It has to be silicone based or else it might eat the rubber O ring, and many ordinary greases also conduct electricity. Not a good idea for a bulb holder!
So, I used Permatex silicone dielectric grease, which is often used on spark plug wire ends to keep them from getting frozen to the spark plugs (yes, on older cars, not e39 M5s). As you will remember from basic electronics, a dielectric is basically an insulator (that may also hold a charge, but won't pass DC current). I smeared just a very thin film on the O ring seal and presto! Easy on, easy off with just light finger pressure.
If I've avoided one more headlamp R&R to get at this bulb, I've more than made up for the cost of the grease.
Need4Spd
Need4Spd is offline
Turn Signal Indicator Anita E39 M5 and E52 Z8 Discussion 19 6th October 2005 15:44
Front signal bulbs 1C00lVC E39 M5 and E52 Z8 Discussion 11 4th February 2003 00:00
How too change the front turn signal bulbs? Micsor/DK E39 M5 and E52 Z8 Discussion 2 29th March 2002 17:34
How too change the front turn signal bulbs? Micsor/DK Off Topic Forum 0 29th March 2002 09:17
And yet, more pics from Sears Point PhilSeastrand E39 M5 and E52 Z8 Discussion 6 21st August 2001 04:17
Page generated in 0.07975 seconds with 11 queries
