Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 3rd October 2004, 03:35   #1
JetDehr
Garage: 2000 M5 S2 Carbon Black
Power loss through 4000rpm
I have a 2000 M5 28,000 miles, with all Dinan upgrades (stage 5 programming, throttle bodies, velocity stacks, Intakes, Meters, headers, exhaust) as well as the supersprint x-pipe. My problem is that I have noticed a power loss as it is sweeping through 4000 rpm. Typically in third gear and above. It is still making power but it plateaus instead of building as it should in the power band. It feels like timing might be being pulled out as it gets into this rpm band at WOT. If I back off and then roll the throttle on again but not to WOT it seems to pull harder than it does at WOT. I'm thinking either it's an over sensitive knocksensor or possibly something else odd like throttle bodies not in sync with where they should be? VANOS problem? Cam timing sensor problem? Weak coil(s)? The engine has strong compression, oil pressure is no problem. Something that may be related is that it runs rough until warmed up as if it is not firing every ignition cycle. Any suggestions? Anybody experienced anything similar?
If you can respond to the post and my personal email to ensure I get the reply that would be great, jetder@aol.com Thanks for your help in advance,
Thor
JetDehr is offline
Old 22nd October 2004, 03:37   #2
ACTECH
Garage: E39 M5 SILVER
Re: Power loss through 4000rpm
Thor
ACTECH is offline
Old 27th June 2008, 22:44   #3
kallijaxl
Garage: bmw e39 m5 carboblue
hy there i had similar problems with mine m5 2000 model.i toke it to my bmw mechanic and he told me that camshaft sensor was broken.it could also be the oxygen sensors or vanos.just let the bmw mechanic check it out.it takes half an 1.camshaft sensor is very cheap but the vanos is expensiv very.if it is vanos you shut check if you can get a vanos repair kit much cheaper.i was very lucky my friend is a car freak and his friend is going to buy it for me in germany very cheap
kallijaxl is offline
Old 28th June 2008, 09:43   #4
MarkQC
MarkQC's Avatar
Garage: M5 E39 Carbon Black -silverstone/black interior
Originally Posted by kallijaxl View Post
.......you can get a vanos repair kit much cheaper.i was very lucky my friend is a car freak and his friend is going to buy it for me in germany very cheap
...any details on this cheap vanos repair kit?
MarkQC is online now
Loss of power during full acceleration, help appreciated icM5er E34 M5 Discussion 2 25th September 2004 05:21
Heat induced power loss PhilSeastrand E39 M5 and E52 Z8 Discussion 3 28th August 2002 08:04
Drive train power loss? johann E39 M5 and E52 Z8 Discussion 7 14th December 2001 19:15
Info about power loss to rear wheels and my NEW M5 HP numbers. Apples E39 M5 and E52 Z8 Discussion 20 8th November 2001 14:35
Page generated in 0.13065 seconds with 11 queries
