Go Back   The Unofficial BMW M5 Messageboard (m5board.com) > General Forums > M5 E39 and E60 tips & tricks
Old 1st July 2004, 22:05   #1
jeffhbmw
jeffhbmw's Avatar
Garage: BMW E39 M5 CARBON BLACK
Angry E39 M5 brake problems
Please help! I have a carbon black E39 M5 2003 model, which has a strange problem with its brakes. When i am travelling at moderate speeds in town traffic and i have to 'feather' the brakes when traffic either slows or comes to a halt in front i have experienced the brake pedal going right down to the carpet! The car is low mileage, well looked after and in pristine condition and owned by me from new. I have had the car into my local BMW dealer countless times but they can find nothing wrong. The pads are fine, the brake fluid has been replaced and bled numerous times but the problem persists. The dealer has even spoken to BMW 'M' in Germany who say this is impossible - but i know because i have experienced it!!!
has anyone else experienced this problem, or has anyone any ideas???
i must mention that under normal/hard usage the brakes are fine.
jeffhbmw is offline
Old 2nd July 2004, 05:53   #2
TCM
TCM's Avatar
Re: E39 M5 brake problems
I have heard of some similiar issues with M5s before. After a long battle, a full replacement of the brake system lines with a proper bleeding seemed to clear things up. Hope this helps.
T.C.
'01 Silverstone M5
SuperSprint:X-pipe
TCM is offline
Old 10th July 2004, 22:18   #3
jaj
jaj's Avatar
Garage: 2008 M3 Coupe Space Grey
I had this on my '01 when it was delivered. I had it once before years ago on another car, and fixed it myself, so I know how it happens.
The problem is a hairline scratch inside the brake master cylinder running lengthwise inside the cylinder, probably from debris when it was made. When you hit the brakes hard, the rubber sliding seal on the piston comes under a lot of pressure and it compresses and squeezes into the scratch and plugs the leak. If you just lightly press the pedal, the rubber doesn't get squeezed into the scratch, and so it doesn't plug the leak and fluid gets around the piston and the pedal sinks gracefully to the floor.
In the old days, you'd just take it apart and hone the master cylinder. Nowadays, they just put in a new one. In any case your dealer will rule the car off the road until it's fixed (mine did), but the good news is that the rest of the braking system is and will continue to be fine.
Cheers
JJ
jaj is offline
Old 12th July 2004, 16:50   #4
jeffhbmw
jeffhbmw's Avatar
In the old days, you'd just take it apart and hone the master cylinder. Nowadays, they just put in a new one. In any case your dealer will rule the car off the road until it's fixed (mine did), but the good news is that the rest of the braking system is and will continue to be fine. - Thanks JJ, i will pass on your info to my local BMW dealer.
Cheers
JJ
jeffhbmw is offline
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 01:11
IMPORTANT FOR E34 M5 OWNERS! Old M5 Messageboard Archive. Help Needed! Gustav E34 M5 Discussion 6 25th February 2006 17:28
(Pics)BMW's Leading to Acquisition E39 M5 (Post Yours Here!) V-10 4 Me E39 M5 and E52 Z8 Discussion 5 13th May 2004 05:40
What do I have to lokk for when buying a M5 E39 ? Turbo Germany E39 M5 and E52 Z8 Discussion 0 10th February 2004 22:38
Page generated in 0.12337 seconds with 11 queries
